Opened 5 years ago
Closed 5 years ago
#870 closed upgrade (Done)
CLARIFICATION: Surface net freshwater flux
Priority: | major | Milestone: | Release ROMS/TOMS 3.9 |
Component: | Nonlinear | Version: | 3.9 |
Several changes were introduced in src:ticket:869 about how to process the surface/bottom tracer fluxes that are used as top/bottom boundary conditions to the vertical diffusion terms. A couple of additional changes are made here to remove any ambiguity about the surface freshwater flux needed for ROMS.
Notice that ROMS has the following vertical surface/bottom boundary condition for temperature and salinity:
In particular, the blue square shows what ROMS needs as a freshwater flux. Usually, E-P is in units of kilogram meter-2 second-1. Then, the flux is divided by freshwater density, which converts to meter second-1. In routine set_vbc.F such flux is multiplied by the surface salinity. Since the salinity does not have physical units, the vertical boundary condition is still in meter second-1.
I cleaned the metadata in varinfo.dat, now we have:
'ssflux' ! Output 'kinematic surface net salt flux, SALT*(E-P)/rhow' 'meter second-1' ! [PSS m/s] 'surface net salt flux, scalar, series' 'ssf_time' 'idTsur(isalt)' 'r2dvar' 1.0d0 'swflux' ! Input 'data surface net freshwater flux, (E-P)/rhow' 'meter second-1' ! Input: [m/s] 'surface net freshwater flux, scalar, series' ! [PSS m/s] 'swf_time' 'idsfwf' 'r2dvar' 1.0d0 'EminusP' ! Input/Output 'modeled surface net freshwater flux, (E-P)/rhow' 'meter second-1' ! computed by NLM ROMS 'EminusP, scalar, series' ! bulk_flux.F or coupling 'ocean_time' 'idEmPf' 'r2dvar' 1.0d0
As specified in the preamble of varinfo.dat, the PSS information is added to indicate that the Practical Salinity Scale was used to determine conductivity, but it is not a physical unit. We are not using the latest UNESCO equation of state.
We have two different variables for input freshwater flux: swflux and EminusP. Historically, swflux has been used for available datasets while EminusP has been used when derived from parameterizations (BULK_FLUXES and atmospheric coupling). To avoid any confusion, the units and scale for swflux were changed to meter second-1 and 1.0d0, respectively. It is the standard unit for freshwater flux. If such field is in centimeter day-1, I recomend to add the scale_factor attribute to the NetCDF, so the conversion is done during reading in ROMS:
float swflux(swf_time, eta_rho, xi_rho) ; swflux:long_name = "surface freshwater flux, (E-P)/rhow" ; swflux:units = "meter second-1" ; swflux:negative = "net evaporation" ; swflux:positive = "net precipitation" ; swflux:time = "swf_time" ; swflux:coordinates = "lon_rho lat_rho swf_time" ; swflux:scale_factor = 1.157407e-07f ;
We could use the Matlab script to adjust the NetCDF file:
nc_attadd('my_file.nc','scale_factor',0.01/86400,'swflux')
- Corrected get_data.F and set_data.F processing of the freshwater flux when the SCORRECTION is activated.
- Corrected compiling issue in regrid.F. It was missing the MASKING conditional.
Change History (1)
comment:1 by , 5 years ago
Resolution: | → Done |
Status: | new → closed |
