Opened 5 years ago
Closed 5 years ago
#848 closed bug (Fixed)
VERY IMPORTANT: Corrected bugs in tracer advection
Priority: | major | Milestone: | Release ROMS/TOMS 3.9 |
Component: | Nonlinear | Version: | 3.9 |
Description ¶
Corrected critical bug in some of the tracer advection options:
- Corrected a bug in the HSIMT advection. Previously, I fixed the issue that three ghost points are needed for this scheme. At that time, I missed making a similar change in the computation of the inverse thickness (oHz). Therefore, in step3d_t.F we need to have
logical :: LapplySrc, Lhsimt, Lmpdata ... Lhsimt =ANY(Hadvection(:,ng)%HSIMT).and. & & ANY(Vadvection(:,ng)%HSIMT) Lmpdata=ANY(Hadvection(:,ng)%MPDATA).and. & & ANY(Vadvection(:,ng)%MPDATA) ... ! ! Compute reciprocal thickness, 1/Hz. ! IF (Lmpdata.or.Lhsimt) THEN DO k=1,N(ng) DO j=Jstrm2,Jendp2 DO i=Istrm2,Iendp2 oHz(i,j,k)=1.0_r8/Hz(i,j,k) END DO END DO END DO ELSE DO k=1,N(ng) DO j=Jstr,Jend DO i=Istr,Iend oHz(i,j,k)=1.0_r8/Hz(i,j,k) END DO END DO END DO END IF
I have been hunting on and off for a bug in the HSIMT scheme for awhile. Many thanks to Pierre St-Laurent for reporting this issue. It is always helpful when another set of eyes look into a code.
- Corrected a weird bug in the tangent linear advection switches. In inp_par.F we need to have instead:
#if defined TANGENT || defined TL_IOMS ! ! Set tracer advection scheme switches for the tangent linear models ! (TLM and RPM) to the same values as the adjoint model. ! DO ng=1,Ngrids DO i=1,NT(ng) tl_Hadvection(i,ng)%AKIMA4 = ad_Hadvection(i,ng)%AKIMA4 tl_Hadvection(i,ng)%CENTERED2 = ad_Hadvection(i,ng)%CENTERED2 tl_Hadvection(i,ng)%CENTERED4 = ad_Hadvection(i,ng)%CENTERED4 tl_Hadvection(i,ng)%HSIMT = ad_Hadvection(i,ng)%HSIMT tl_Hadvection(i,ng)%MPDATA = ad_Hadvection(i,ng)%MPDATA tl_Hadvection(i,ng)%SPLINES = ad_Hadvection(i,ng)%SPLINES tl_Hadvection(i,ng)%SPLIT_U3 = ad_Hadvection(i,ng)%SPLIT_U3 tl_Hadvection(i,ng)%UPSTREAM3 = ad_Hadvection(i,ng)%UPSTREAM3 ! tl_Vadvection(i,ng)%AKIMA4 = ad_Vadvection(i,ng)%AKIMA4 tl_Vadvection(i,ng)%CENTERED2 = ad_Vadvection(i,ng)%CENTERED2 tl_Vadvection(i,ng)%CENTERED4 = ad_Vadvection(i,ng)%CENTERED4 tl_Vadvection(i,ng)%HSIMT = ad_Vadvection(i,ng)%HSIMT tl_Vadvection(i,ng)%MPDATA = ad_Vadvection(i,ng)%MPDATA tl_Vadvection(i,ng)%SPLINES = ad_Vadvection(i,ng)%SPLINES tl_Vadvection(i,ng)%SPLIT_U3 = ad_Vadvection(i,ng)%SPLIT_U3 tl_Vadvection(i,ng)%UPSTREAM3 = ad_Vadvection(i,ng)%UPSTREAM3 END DO END DO #endif
Before, the assigment was to use the nonlinear values instead. As a consequence, the 4D-Var cost function was not decreasing correctly and the minimization failed because the broken symmetry between tangent linear (TLM) and adjoint (ADM) model operators. We need to have the same advection scheme in both TLM and ADM. Recall that in roms.in, the user specify just the values for the adjoint model.
Many thanks to Julia Levin for reporting this problem and Andy Moore for his help in debugging.
Note:
See TracTickets
for help on using tickets.
