Opened 6 years ago
Closed 6 years ago
#805 closed request (Done)
New option: PRESS_COMPENSATE
Reported by: m.hadfield Owned by:
Keywords: Cc:
The PRESS_COMPENSATE code in my fork of Rutgers ROMS is used along with ATM_PRESS (inverse barometer effect) so that you can run a model with ATM_PRESS but drive it with lateral boundary zeta data from a model without ATM_PRESS (eg. most of the larger-scale ocean models). See
https://www.myroms.org/forum/viewtopic.php?f=4&t=4780#p18559
I haven't used or tested PRESS_COMPENSATE for a while, because I haven't used ATM_PRESS, but I'm starting to become interested again in having my models simulate storm surge. So I will dig up an old example and check it out. But I see no reason why the code would have broken in the meantime.
It's implemented only in the Nonlinear model.
Modified files are attached.
Change History (5)
by m.hadfield, 6 years ago
Attachment: cppdefs.h added
Attachment: checkdefs.F added
Attachment: u2dbc_im.F added
Attachment: v2dbc_im.F added
comment:1 by arango, 6 years ago
Description: modified (diff)
Resolution: Done
Status: newclosed
Summary: PRESS_COMPENSATENew option: PRESS_COMPENSATE
Thank you, Mark. I reformatted a little to facilitate the tangent and adjoint versions of the new option.
