Opened 7 years ago
Closed 7 years ago
#790 closed upgrade (Done)
Change allocation of FOURDVAR structure
Reported by: arango Owned by:
Component: Adjoint Version: 3.7
Keywords: Cc:
Description
  • For the convenience of allocating and deallocating, the arrays in the structure FOURDVAR(ng) are now declared as allocatable instead of a pointer in mod_fourdvar.F. So now we have:
    !  Define module structure.
            TYPE T_FOURDVAR
              integer , allocatable :: NobsSurvey(:)
              integer , allocatable :: ObsCount(:)
              integer , allocatable :: ObsReject(:)
            END TYPE T_FOURDVAR
            TYPE (T_FOURDVAR), allocatable :: FOURDVAR(:)
    The change is made to facilitate new 4D-Var algorithms currently under development.
  • Also, corrected a minor bug in read_asspar.F when processing keywords Iprovenance and P_bgqc:
    #  ifdef BGQC
                CASE ('Iprovenance')
                  Mval=MAXVAL(Nprovenance)
                  Npts=load_i(Nval, Rval, Mval, Ngrids, Iprovenance)
                CASE ('P_bgqc')
                  Npts=load_r(Nval, Rval, Mval, Ngrids, P_bgqc)
    #  endif
    because it has the wrong number of arguments to load_i and load_r since both Iprovenance and P_bgqc are 2D arrays.
Change History (1)
comment:1 by arango, 7 years ago
Resolution: Done
Status: newclosed
