Opened 7 years ago
Closed 7 years ago
#773 closed bug (Fixed)
small stuff for gfortran and -fcheck=all
Reported by: kate Owned by:
Priority: minor Milestone: Release ROMS/TOMS 3.7
Keywords: Cc:
While compiling with the gfortran compiler and the following flags:
 -fcheck=all -fsanitize=address -fsanitize=undefined
we discovered few issues. The routines wclock_on and wclock_off need to be recursive.Also, LBC%reduced not initialized in mod_param.F.
The routines read_phypar.F and read_stapar.F were modified to suppress lots of warnings in gfortran:
At line XXX of file read_phypar.f90
Fortran runtime warning: An array temporary was created
Change History (2)
by kate, 7 years ago
Attachment: gfortran_checking.diff added
patch file to fix issue
comment:1 by arango, 7 years ago
Description: modified (diff)
Resolution: Fixed
Status: newclosed
Yes, thank you. I also fixed the issues with read_phypar.F and read_stapar.F. There is still an issue with the random number generator (routine ran_init), but there is nothing that we can do. It seems that gfortran doesn't support 32-bit integer under negation and wrap-around addition.
