Opened 7 years ago
Closed 7 years ago
#766 closed upgrade (Done)
Minor update to facilitate multi-model coupling
Component: | Nonlinear | Version: | 3.7 |
Description ¶
- The internal CPP option ATM_COUPLING is renamed to FRC_COUPLING since it is possible to couple to an atmospheric model or a data model (DATA_COUPLING) for the same forcing fields. It is done to consolidate with the coupling research branch that uses the ESMF/NUOPC library.
- Introduced CPP option ROMS_STDOUT to redirect ROMS standard output information to file log.roms. It coupling is advantageous to separate the standard output information of all the coupled Earth System Model (ESM) components to different log files. It is easier to track the solution of each ESM component when they are separated. In inp_par.F, we now have:
#ifdef ROMS_STDOUT ! ! Change default Fortran standard out unit, so ROMS run information is ! directed to a file. This is advantageous in coupling applications to ! ROMS information separated from other models. ! stdout=20 ! overwite Fortran default unit 6 ! OPEN (stdout, FILE='log.roms', FORM='formatted', & & STATUS='replace') #endif
Changed several routines to replace PRINT statements with WRITE (stdout,*).
- Update ROMS Nonlinear model driver nl_ocean.h to provide the correct information to time stepping kernel during model coupling:
! ! Local variable declarations. ! #if defined MODEL_COUPLING && !defined MCT_LIB logical, save :: FirstPass = .TRUE. #endif integer :: ng #if defined MODEL_COUPLING && !defined MCT_LIB integer :: NstrStep, NendStep #endif real (r8) :: MyRunInterval ! !----------------------------------------------------------------------- ! Time-step nonlinear model over all nested grids, if applicable. #if defined MODEL_COUPLING && !defined MCT_LIB ! On first pass, add a timestep to the coupling interval to account ! for ROMS kernel delayed delayed output until next timestep. #endif !----------------------------------------------------------------------- ! MyRunInterval=RunInterval IF (Master) WRITE (stdout,'(1x)') DO ng=1,Ngrids #if defined MODEL_COUPLING && !defined MCT_LIB step_counter(ng)=0 NstrStep=iic(ng) IF (FirstPass) THEN NendStep=NstrStep+INT((RunInterval+dt(ng))/dt(ng)) IF (ng.eq.1) MyRunInterval=MyRunInterval+dt(ng) FirstPass=.FALSE. ELSE NendStep=NstrStep+INT(MyRunInterval/dt(ng)) END IF IF (Master) WRITE (stdout,10) 'NL', ng, NstrStep, NendStep #else IF (Master) WRITE (stdout,10) 'NL', ng, ntstart(ng), ntend(ng) #endif END DO IF (Master) WRITE (stdout,'(1x)') ! !$OMP PARALLEL #ifdef SOLVE3D CALL main3d (MyRunInterval) #else CALL main2d (MyRunInterval) #endif !$OMP END PARALLEL
Recall that MyRunInterval may span the full period of the simulation, a multi-model coupling interval (RunInterval > ifac*dt), or just a single step (RunInterval=0). The zero value here is valid and can be explained by ROMS design of delayed output.
Note:
See TracTickets
for help on using tickets.
