Opened 7 years ago
Closed 7 years ago
#763 closed upgrade (Done)
IMPORTANT: More robust logic in check_multifile.F
Reported by: arango Owned by:
Keywords: Cc:
Description
Changed the logic in check_multifile.F to compute local variable Tfinal from:
!  Get final time string for simulation.
      IF (model.eq.iADM) THEN
        Tfinal=dstart*day2sec
      ELSE
        Tfinal=dstart*day2sec+ntimes(ng)*dt(ng)
      CALL time_string (tfinal, F_code)
to
        Tfinal=time(ng)-ntimes(ng)*dt(ng)
      ELSE
        Tfinal=time(ng)+ntimes(ng)*dt(ng)
The latest is more robust because it doesn't depend on the user manipulation of DSTART in ocean.in. Under certain conditions the checking of input files may fail in check_multifile.F.
Also, I added precise error reporting in the routine inquiry.F.
Many thanks to Julia Levin for bringing this to my attention.
Change History (1)
comment:1 by arango, 7 years ago
Resolution: Done
Status: newclosed
