Opened 8 years ago
Closed 8 years ago
#749 closed upgrade (Done)
Important: Miscelaneous Update: GLS and standard ouput information
Reported by: arango Owned by:
Keywords: Cc:
Description
This important update corrects few things and enhances information written to standard output:
  • Corrected a bug in the drivers afte_ocean.h and fte_ocean.h (Finite Time Eigenmodes algorithms). We were getting segmentation violation after the convergence. The work array used to compute the complex eigenvectors was wrong. We need to use SworkR instead of SworkD. For example, we need to have:
                        state(ng)%vector => STORAGE(ng)%Rvector(Is:Ie,i)
                        ad_state(ng)%vector => SworkR(Is:Ie)
    instead of
                        ad_state(ng)%vector => STORAGE(ng)%SworkD(Is:Ie)
    Many thanks to Andy Moore for bringing this to my attention.
  • Added new module ROMS/Utility/stats.F to compute state field statistics inside a parallel region using routines stats_2dfld and stats_3dfld. Both routines are used to print information from analytical routines (ana_biology, ana_drag, ana_grid, ana_initial, ana_mask, ana_wtype). For example, in the upwelling test case the standard output file now has:
        ANA_GRID    - x-location of PSI-points: x_psi
                       (Grid = 01, Min =  0.00000000E+00 Max =  4.00000000E+04)
        ANA_GRID    - y-location of PSI-points: y_psi
                       (Grid = 01, Min =  0.00000000E+00 Max =  8.00000000E+04)
        ANA_GRID    - x-location of RHO-points: x_rho
                       (Grid = 01, Min =  5.00000000E+02 Max =  4.05000000E+04)
        ANA_GRID    - y-location of RHO-points: y_rho
                       (Grid = 01, Min = -5.00000000E+02 Max =  8.05000000E+04)
        ANA_GRID    - x-location of U-points: x_u
        ANA_GRID    - y-location of U-points: y_u
        ANA_GRID    - x-location of V-points: x_v
        ANA_GRID    - y-location of V-points: y_v
        ANA_GRID    - reciprocal XI-grid spacing: pm
                       (Grid = 01, Min =  1.00000000E-03 Max =  1.00000000E-03)
        ANA_GRID    - reciprocal ETA-grid spacing: pn
        ANA_GRID    - angle between XI-axis and EAST: angler
                       (Grid = 01, Min =  0.00000000E+00 Max =  0.00000000E+00)
        ANA_GRID    - Coriolis parameter at RHO-points: f
                       (Grid = 01, Min = -8.26000000E-05 Max = -8.26000000E-05)
        ANA_GRID    - bathymetry at RHO-points: h
                       (Grid = 01, Min =  2.52004887E+01 Max =  1.50000000E+02)
        ANA_INITIAL - vertically integrated u-momentum component: ubar
        ANA_INITIAL - vertically integrated v-momentum component: vbar
        ANA_INITIAL - free-surface: zeta
        ANA_INITIAL - u-momentum component: u
        ANA_INITIAL - v-momentum component: v
        ANA_INITIAL - potential temperature: temp
                       (Grid = 01, Min =  1.45204834E+01 Max =  2.19365219E+01)
        ANA_INITIAL - salinity: salt
                       (Grid = 01, Min =  3.50000000E+01 Max =  3.50000000E+01)
        ANA_BIOLOGY - nitrate concentration: NO3
                       (Grid = 01, Min =  1.67000000E+00 Max =  2.26358685E+00)
        ANA_BIOLOGY - ammonium concentration: NH4
                       (Grid = 01, Min =  1.00000000E-01 Max =  1.00000000E-01)
        ANA_BIOLOGY - chlorophyll concentration: chlorophyll
                       (Grid = 01, Min =  2.00000000E-02 Max =  2.00000000E-02)
        ANA_BIOLOGY - phytoplankton concentration: phytoplankton
                       (Grid = 01, Min =  8.00000000E-02 Max =  8.00000000E-02)
        ANA_BIOLOGY - zooplankton concentration: zooplankton
                       (Grid = 01, Min =  6.00000000E-02 Max =  6.00000000E-02)
        ANA_BIOLOGY - large fraction nitrogen detritus concentration: LdetritusN
        ANA_BIOLOGY - small fraction nitrogen detritus concentration: SdetritusN
                       (Grid = 01, Min =  4.00000000E-02 Max =  4.00000000E-02)
        ANA_BIOLOGY - large fraction carbon detritus concentration: LdetritusC
                       (Grid = 01, Min =  2.00000000E-03 Max =  2.00000000E-03)
        ANA_BIOLOGY - small fraction carbon detritus concentration: SdetritusC
        ANA_BIOLOGY - total inorganic carbon: TIC
                       (Grid = 01, Min =  2.10000000E+03 Max =  2.10000000E+03)
        ANA_BIOLOGY - total alkalinity: alkalinity
                       (Grid = 01, Min =  2.35000000E+03 Max =  2.35000000E+03)
        ANA_BIOLOGY - dissolved oxygen concentration: oxygen
                       (Grid = 01, Min =  4.46229362E+02 Max =  4.46229362E+02)
    This information is useful to have. Many thanks to Kate Hedstrom for suggesting this information and Sasha Shchepetkin for his suggestion about the shared-memory interference (race conditions in OpenMP) issues that I was having in stats_2dfld and stats_3dfld.
  • Similarly, statistical information is written to standard output from routines get_grid, get_nudgcoef, and get_wetdry.
        GET_GRID    - angle between XI-axis and EAST: angle
                       (Grid = 01, File: ../Data/grid_doppio_7km_sponge_v3.nc)
                       (Min =  5.38487353E-01 Max =  7.47524111E-01)
        GET_GRID    - ETA-derivative of inverse metric factor pm: dmde
                       (Min = -1.33890089E+00 Max =  2.92981308E-01)
        GET_GRID    - XI-derivative of inverse metric factor pn: dndx
                       (Min = -8.94234719E-01 Max =  2.44594681E-01)
        GET_GRID    - Coriolis parameter at RHO-points: f
                       (Min =  7.77782704E-05 Max =  1.05954391E-04)
        GET_GRID    - bathymetry at RHO-points: h
                       (Min =  5.00000000E+00 Max =  5.01558186E+03)
        GET_GRID    - latitude of PSI-points lat_psi
                       (Min =  3.22838550E+01 Max =  4.65684505E+01)
        GET_GRID    - latitude of RHO-points lat_rho
        GET_GRID    - latitude of U-points: lat_u
                       (Min =  3.22596780E+01 Max =  4.65941314E+01)
        GET_GRID    - latitude of V-points: lat_v
                       (Min =  3.22636115E+01 Max =  4.65856422E+01)
        GET_GRID    - longitude of PSI-points: lon_psi
                       (Min = -8.04626893E+01 Max = -5.97474687E+01)
        GET_GRID    - longitude of RHO-points: lon_rho
        GET_GRID    - longitude of U-points: lon_u
                       (Min = -8.04896326E+01 Max = -5.97260683E+01)
        GET_GRID    - longitude of V-points: lon_v
                       (Min = -8.04917457E+01 Max = -5.97116752E+01)
        GET_GRID    - mask on PSI-points: mask_psi
                       (Min =  0.00000000E+00 Max =  2.00000000E+00)
        GET_GRID    - mask on RHO-points: mask_rho
                       (Min =  0.00000000E+00 Max =  1.00000000E+00)
        GET_GRID    - mask on U-points: mask_u
        GET_GRID    - mask on V-points: mask_v
        GET_GRID    - reciprocal XI-grid spacing: pm
                       (Min =  1.42195423E-04 Max =  1.45208703E-04)
        GET_GRID    - reciprocal ETA-grid spacing: pn
                       (Min =  1.42589316E-04 Max =  1.45608589E-04)
        GET_GRID    - x-location of PSI-points: x_psi
                       (Min =  5.10981935E+07 Max =  5.34016198E+07)
        GET_GRID    - x-location of RHO-points: x-rho
                       (Min =  5.10919665E+07 Max =  5.34079786E+07)
        GET_GRID    - x-location of U-points: x_u
                       (Min =  5.10951975E+07 Max =  5.34039995E+07)
        GET_GRID    - x-location of V-points: x_v
                       (Min =  5.10949626E+07 Max =  5.34055999E+07)
        GET_GRID    - y-location of PSI-points: y-psi
                       (Min =  6.33431802E+07 Max =  6.54121491E+07)
        GET_GRID    - y-location of RHO-points: y_rho
                       (Min =  6.33373400E+07 Max =  6.54190868E+07)
        GET_GRID    - y-location of U-points: y_u
                       (Min =  6.33400007E+07 Max =  6.54163037E+07)
        GET_GRID    - y-location of V-points: y_v
                       (Min =  6.33405179E+07 Max =  6.54149301E+07)
        GET_GRID    - quadratic bottom drag coefficient: rdrag2
                       (Min =  3.00000000E-03 Max =  3.00000000E-03)
       GET_NUDGCOEF - potential temperature, inverse nudging coefficients: temp_NudgeCoef
                       (Grid = 01, File: ../Data/doppio_nudgcoef_7km_deepGS_3dayperim.nc)
                       (Min =  0.00000000E+00 Max =  3.85802469E-06)
       GET_NUDGCOEF - salinity, inverse nudging coefficients: salt_NudgeCoef
  • Modified several routines to provide more information when an input file is missing from ocean.in. In the past, we use to get the following error:
    Found Error: **   Line: 6565     Source: ROMS/Modules/mod_netcdf.F, netcdf_open
                   call from:  ROMS/Utility/inp_par.F, find_file
    Now, we get better information about the error:
    INP_PAR:FIND_FILE - empty file name string for standard input script
                        KeyWord: TIDENAME
    Found Error: 05   Line: 1396     Source: ROMS/Utility/inp_par.F
    READ_PHYPAR - Grid 01, could not find input file:  Oops unassigned file name.
                                                       Check standard input script...
    Found Error: 04   Line: 5674     Source: ROMS/Utility/read_phypar.F
    Found Error: 04   Line: 139      Source: ROMS/Utility/inp_par.F
    Found Error: 04   Line: 111      Source: ROMS/Drivers/nl_ocean.h
    This information is more useful and tell me that the file name for keyWord TIDENAME is missing from ocean.in and this input script needs to be updated to the lastest version.
  • Modified several routines, so the diagnostic printed to standard output have identical numbers in serial, serial with partitions, parallel distributed-memory (MPI), and parallel shared-memory (OpenMP) applications. Several of the global parallel reduction CRITICAL sections were updated.
Change History (1)
comment:1 by arango, 8 years ago
Resolution: Done
Status: newclosed
