Opened 8 years ago
Closed 8 years ago
#723 closed bug (Fixed)
Misceleaneous corrections
Component: | Nonlinear | Version: | 3.7 |
Several miscellaneous corrections are applied:
- Using potential/neutral (pden) density in the tracer diffusion isopycnic tensor in routines t3dmix2_iso.h and t3dmix4_iso.h. It was using in situ density (rho). Oops, I missed this one. I just discovered by looking at those routines. I thought that we were using pden.
- Correct the extraction of free-surface in shallow-water nesting applications. We need instead in nesting.F routine get_refine:
# ifdef SOLVE3D CALL get_contact2d (dg, model, tile, & & r2dvar, 'Zt_avg1', & & cr, Rcontact(cr)%Npoints, Rcontact, & & LBi, UBi, LBj, UBj, & & COUPLING(dg) % Zt_avg1, & & REFINED(cr) % zeta(:,:,tnew)) # else CALL get_contact2d (dg, model, tile, & & r2dvar, 'zeta', & & cr, Rcontact(cr)%Npoints, Rcontact, & & LBi, UBi, LBj, UBj, & & OCEAN(dg) % zeta(:,:,Tindex2d), & & REFINED(cr) % zeta(:,:,tnew)) # endif
- Added wet/dry mask during penetration of solar radiation into the water column in pre_step3d.F:
# ifdef SOLAR_SOURCE ! ! Add in incoming solar radiation at interior W-points using decay ! decay penetration function based on Jerlov water type. ! IF (itrc.eq.itemp) THEN DO k=1,N(ng)-1 DO i=Istr,Iend FC(i,k)=FC(i,k)+ & & dt(ng)*srflx(i,j)* & # ifdef WET_DRY & rmask_wet(i,j)* & # endif & swdk(i,j,k) END DO END DO END IF # endif
Change History (1)
comment:1 by , 8 years ago
Resolution: | → Fixed |
Status: | new → closed |
Summary: | Misceleaneous → Misceleaneous corrections |
Note:
See TracTickets
for help on using tickets.
