Opened 10 years ago
Closed 9 years ago
#687 closed bug (Fixed)
NetCDF clm_file attribute is incomplete
Reported by: m.hadfield Owned by: arango
Priority: trivial Milestone: Release ROMS/TOMS 3.7
Keywords: Cc:
I have noticed that when my ROMS simulations uses multiple boundary files and the same number of climatology files, then in the output netCDF files the bry_file global attribute lists all the boundary files in a comma-separated list, but the clm_file attribute gives only one.
The reason is apparent on reading ROMS/Utility/def_info.F, lines 567 and 583. At the former, a list of boundary files is constructed with the join_string procedure and then written to the bry_file attribute. At the latter a similar list is constructed, but it is never used.
Corrected version attached.
Attachments (1)
def_info.F (119.1 KB ) - added by m.hadfield 10 years ago.
Download all attachments as: .zip
Change History (2)
by m.hadfield, 10 years ago
Attachment: def_info.F added
comment:1 by arango, 9 years ago
Description: modified (diff)
Resolution: Fixed
Status: newclosed
Yes, good catch.
I also added the reporting of var_info that was accidentally removed in src:ticket:373 on 11 Nov 2009. Many thanks to John Wilkin for bringing this to my attention.
