Opened 10 years ago
Closed 10 years ago
#680 closed upgrade (Done)
IMPORTANT: stations and floats in nesting applications
Component: | Nonlinear | Version: | 3.7 |
STATIONS:
The routine read_stapar.F that reads the stations input script (stations.in) was updated so the CPP option STATIONS is more robust across nested grids. Only one stations.in input script is needed in nested applications. As in ocean.in, we just need to use the plural symbol == after the KEYWORD for relevant nested grids parameters.
For example, in a four nested grids application we can have:
! Switch to control the writing of stations data within nested and/or multiple ! connected grids, [1:Ngrids]. Lstations == T T T T ! Logical switches (TRUE/FALSE) to activate writing of fields in STATION ! output file, [Sout(:,ng), ng=1, Ngrids]. Sout(idUvel) == 4*T ! u 3D U-velocity Sout(idVvel) == 4*T ! v 3D V-velocity Sout(idu3dE) == 4*F ! u_eastward 3D U-eastward at RHO-points Sout(idv3dN) == 4*F ! v_northward 3D V-nortward at RHO-points Sout(idWvel) == 4*T ! w 3D W-velocity Sout(idOvel) == 4*T ! omega 3D omega vertical velocity Sout(idUbar) == 4*T ! ubar 2D U-velocity Sout(idVbar) == 4*T ! vbar 2D V-velocity Sout(idu2dE) == 4*F ! ubar_eastward 2D U-eastward at RHO-points Sout(idv2dN) == 4*F ! vbar_northward 2D V-northward at RHO-points Sout(idFsur) == 4*T ! zeta free-surface Sout(idBath) == 4*T ! bath time-dependent bathymetry Sout(idTvar) == 8*T ! temp, salt, ... all (NT) tracers Sout(idUsms) == 4*T ! sustr surface U-stress Sout(idVsms) == 4*T ! svstr surface V-stress Sout(idUbms) == 4*T ! bustr bottom U-stress Sout(idVbms) == 4*T ! bvstr bottom V-stress Sout(idUbrs) == 4*F ! bustrc bottom U-current stress Sout(idVbrs) == 4*F ! bvstrc bottom V-current stress Sout(idUbws) == 4*F ! bustrw bottom U-wave stress Sout(idVbws) == 4*F ! bvstrw bottom V-wave stress Sout(idUbcs) == 4*F ! bustrcwmax bottom max wave-current U-stress Sout(idVbcs) == 4*F ! bvstrcwmax bottom max wave-current V-stress Sout(idUbot) == 4*F ! Ubot bed wave orbital U-velocity Sout(idVbot) == 4*F ! Vbot bed wave orbital V-velocity Sout(idUbur) == 4*F ! Ur bottom U-velocity above bed Sout(idVbvr) == 4*F ! Vr bottom V-velocity above bed Sout(idW2xx) == 4*F ! Sxx_bar 2D radiation stress, Sxx component Sout(idW2xy) == 4*F ! Sxy_bar 2D radiation stress, Sxy component Sout(idW2yy) == 4*F ! Syy_bar 2D radiation stress, Syy component Sout(idU2rs) == 4*F ! Ubar_Rstress 2D radiation U-stress Sout(idV2rs) == 4*F ! Vbar_Rstress 2D radiation V-stress Sout(idU2Sd) == 4*F ! ubar_stokes 2D U-Stokes velocity Sout(idV2Sd) == 4*F ! vbar_stokes 2D V-Stokes velocity Sout(idW3xx) == 4*F ! Sxx 3D radiation stress, Sxx component Sout(idW3xy) == 4*F ! Sxy 3D radiation stress, Sxy component Sout(idW3yy) == 4*F ! Syy 3D radiation stress, Syy component Sout(idW3zx) == 4*F ! Szx 3D radiation stress, Szx component Sout(idW3zy) == 4*F ! Szy 3D radiation stress, Szy component Sout(idU3rs) == 4*F ! u_Rstress 3D U-radiation stress Sout(idV3rs) == 4*F ! v_Rstress 3D V-radiation stress Sout(idU3Sd) == 4*F ! u_stokes 3D U-Stokes velocity Sout(idV3Sd) == 4*F ! v_stokes 3D V-Stokes velocity Sout(idWamp) == 4*F ! Hwave wave height Sout(idWlen) == 4*F ! Lwave wave length Sout(idWdir) == 4*F ! Dwave wave direction Sout(idWptp) == 4*F ! Pwave_top wave surface period Sout(idWpbt) == 4*F ! Pwave_bot wave bottom period Sout(idWorb) == 4*F ! Ub_swan wave bottom orbital velocity Sout(idWdis) == 4*F ! Wave_dissip wave dissipation Sout(idPair) == 4*F ! Pair surface air pressure Sout(idUair) == 4*F ! Uair surface U-wind component Sout(idVair) == 4*F ! Vair surface V-wind component Sout(idTsur) == 8*F ! shflux, ssflux surface net heat and salt flux Sout(idLhea) == 4*F ! latent latent heat flux Sout(idShea) == 4*F ! sensible sensible heat flux Sout(idLrad) == 4*F ! lwrad longwave radiation flux Sout(idSrad) == 4*F ! swrad shortwave radiation flux Sout(idEmPf) == 4*F ! EminusP E-P flux Sout(idevap) == 4*F ! evaporation evaporation rate Sout(idrain) == 4*F ! rain precipitation rate Sout(idDano) == 4*T ! rho density anomaly Sout(idVvis) == 4*T ! AKv vertical viscosity Sout(idTdif) == 4*T ! AKt vertical T-diffusion Sout(idSdif) == 4*T ! AKs vertical Salinity diffusion Sout(idHsbl) == 4*T ! Hsbl depth of surface boundary layer Sout(idHbbl) == 4*F ! Hbbl depth of bottom boundary layer Sout(idMtke) == 4*F ! tke turbulent kinetic energy Sout(idMtls) == 4*F ! gls turbulent length scale ! Logical switches (TRUE/FALSE) to activate writing of exposed sediment ! layer properties into STATIONS output file. Currently, MBOTP properties ! are expected for the bottom boundary layer and/or sediment models: ! ! idBott( 1=isd50) grain_diameter mean grain diameter ! idBott( 2=idens) grain_density mean grain density ! idBott( 3=iwsed) settling_vel mean settling velocity ! idBott( 4=itauc) erosion_stress critical erosion stress ! idBott( 5=irlen) ripple_length ripple length ! idBott( 6=irhgt) ripple_height ripple height ! idBott( 7=ibwav) bed_wave_amp wave excursion amplitude ! idBott( 8=izdef) Zo_def default bottom roughness ! idBott( 9=izapp) Zo_app apparent bottom roughness ! idBott(10=izNik) Zo_Nik Nikuradse bottom roughness ! idBott(11=izbio) Zo_bio biological bottom roughness ! idBott(12=izbfm) Zo_bedform bed form bottom roughness ! idBott(13=izbld) Zo_bedload bed load bottom roughness ! idBott(14=izwbl) Zo_wbl wave bottom roughness ! idBott(15=iactv) active_layer_thickness active layer thickness ! idBott(16=ishgt) saltation saltation height ! ! 1 1 1 1 1 1 1 ! 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 Sout(idBott) == F F F F F F F F F F F F F F F F \ F F F F F F F F F F F F F F F F \ F F F F F F F F F F F F F F F F \ F F F F F F F F F F F F F F F F ! Number of stations to process in each nested grid. These values are ! essential because the station arrays are dynamically allocated using ! these values, [1:Ngrids]. NSTATION == 1 1 1 1 ! Station locations for all grids in any desired order. The horizontal ! location for a particular station may be specified in terms of fractional ! (I,J) grid pairs (FLAG=0) or (longitude,latitude) grid pairs (FLAG=1). ! Here, FLAG is a special switch and may be used for multiple purposes. ! The GRID column indicates nested grid number to process. This value must ! be one in non-nested applications. The COMMENT section is ignored during ! reading and may be used to help documentation. POS = GRID FLAG X-POS Y-POS COMMENT 1 0 50.0d0 40.0d0 2 0 60.0d0 65.0d0 3 0 57.0d0 30.0d0 4 0 66.0d0 25.0d0
Users need to pay attention to all the above parameters. In particular: Lstations, NSTATION, and POS.
FLOATS:
Similarly, one floats.in is need in nested applications when the CPP option FLOATS is activated. Currently, the floats trajectories are independent of each nested grid. That is, once that the trajectory exit a particular grid it will not continue into the other nested grids. We will figure out in the future how to allow this but it is not high in our priority list.
As mentioned above, we just need to use the plural symbol == after the KEYWORD for nested grids parameters. For example, in a four nested grids application we can have:
! Switch to control the computation of floats trajectories within nested ! and/or multiple connected grids, [1:Ngrids]. ! Lfloats == T F F F ! Switch to control the printing of floats initial positions to standard ! output file, [1:Ngrids]. ! Fprint == T T T T ! Flag indicating re-start from previous solution. If FRREC = 0, a new ! NetCDF output file is created. FRREC == 4*0 ! If applicable, input script file name containing biological floats behavior ! model parameters. FBIONAM = behavior_oyster.in ! Number of floats to release in each nested grid. These values are ! essential because the FLOATS structure in "mod_floats" is dynamically ! allocated using these values, [1:Ngrids]. NFLOATS == 1 1 1 1 ! Initial floats locations for all grids: ! ! G Nested grid number ! C Initial horizontal coordinate type (0: grid units, 1: spherical) ! T Float trajectory type (1: Lagrangian, 2: isobaric, 3: Geopotential) ! N Number floats to be released at (Fx0,Fy0,Fz0) ! Ft0 Float release time (days) after model initialization ! Fx0 Initial float X-location (grid units or longitude) ! Fy0 Initial float Y-location (grid units or latitude) ! Fz0 Initial float Z-location (grid units or depth) ! Fdt Float cluster release time interval (days) ! Fdx Float cluster X-distribution parameter ! Fdy Float cluster Y-distribution parameter ! Fdz Float cluster Z-distribution parameter POS = G, C, T, N, Ft0, Fx0, Fy0, Fz0, Fdt, Fdx, Fdy, Fdz 1 0 1 1 0.0d0 50.0d0 40.0d0 8.0d0 0.0d0 0.0d0 0.0d0 0.0d0 2 0 1 1 0.0d0 60.0d0 65.0d0 8.0d0 0.0d0 0.0d0 0.0d0 0.0d0 3 0 1 1 0.0d0 57.0d0 30.0d0 8.0d0 0.0d0 0.0d0 0.0d0 0.0d0 4 0 1 1 0.0d0 66.0d0 25.0d0 8.0d0 0.0d0 0.0d0 0.0d0 0.0d0
Users need to pay attention to the following parameters Lfloats, NFLOATS. and POS.
Corrected nesting.F around Line 122 to avoid compilation problems when MASKING is not activated:
# if defined MASKING || defined WET_DRY PRIVATE :: mask_hweights # endif
Many thanks to Jamie Pringle for bringing this to my attention.
Change History (1)
comment:1 by , 10 years ago
Resolution: | → Done |
Status: | new → closed |
