Opened 18 years ago
Closed 18 years ago
#68 closed bug (Done)
nf_fread error checking
Reported by: | jcwarner | Owned by: | arango |
Priority: | minor | Milestone: | Release ROMS/TOMS 3.1 |
Component: | Nonlinear | Version: | 3.1 |
Keywords: | nf_fread | Cc: |
In function ROMS/Utility/nf_fread2d, lines 223:237 *
status=nf90_noerr IF (InpThread) THEN status=nf90_get_var(ncid, ncvarid, wrk, start, total) IF (status.eq.nf90_noerr) THEN ... END IF END IF ... IF (status.ne.nf90_noerr) RETURN
If the file is not read correctly, then "status" will not equal nf90_noerr, and the code will return. But we need to have the value of "nf_fread" set to = the value of status before the return happens. IF the file is read correctly, then at the bottom of nf_fread2d we have:
nf_fread2d=status
so that is ok.
Suggest that we add a line
nf_fread2d=status
before the return statement. This also needs to be addressed in read 3d, 4d.
Change History (1)
comment:1 by , 18 years ago
Resolution: | → Done |
Status: | new → closed |
Note:
See TracTickets
for help on using tickets.
