Opened 11 years ago
Closed 11 years ago
#650 closed bug (Fixed)
Corrected bugs in inp_par.F
Component: | Nonlinear | Version: | 3.7 |
Description
Several reported bugs were corrected:
- inp_par.F: Corrected the Rad+Nud boundary conditions for passive tracer when the compact specification is used and input data is required. Many thanks to Mark Hadfield for reporting this bug and a solution. We just needed to add:
#ifdef SOLVE3D ! ! If processing tracers and last standard input entry (Icont=0), set ! unspecified tracer values to the last tracer entry. ! IF ((iTrcStr.gt.0).and.(iTrcEnd.gt.0)) THEN IF ((Icont.eq.0).and.(ifield.lt.isTvar(iTrcEnd))) THEN DO i=ifield+1,isTvar(iTrcEnd) DO ibry=1,4 ... S(ibry,i,igrid)%acquire = S(ibry,ifield,igrid)%acquire END DO ic=ic+1 END DO END IF END IF #endif
- inp_par.F: Corrected the momentum LnudgeM3CLM switch. Many thanks to Xueming zhu and Mark Hadfield for reporting this. We just need to have:
! ! Set internal switch for nudging to climatology fields. ! #ifdef SOLVE3D IF (LnudgeM3CLM(ng).or. & & LnudgeM3CLM(ng).or. & & ANY(LnudgeTCLM(:,ng))) THEN Lnudging(ng)=.TRUE. END IF #else IF (LnudgeM2CLM(ng)) THEN Lnudging(ng)=.TRUE. END IF #endif
- def_rst.F: Corrected typo when defining wetdry_psi mask. This does not affect solution. Many thanks to Kate Hedstrom for reporting this. We just need to have:
Aval(5)=REAL(Iinfo(1,idPwet,ng),r8)
The other changes are for readability.
Note:
See TracTickets
for help on using tickets.
