Opened 12 years ago
Closed 12 years ago
#614 closed bug (Fixed)
IMPORTANT: Corrected nesting refinement algorithms
Component: | Nonlinear | Version: | 3.7 |
Corrected several problems with the grid refinement algorithms. The DOGBONE test case for refinement is work well now. I am now working on nesting application in the Gulf of Mexico and South China Sea to fine tune the algorithms to complex realistic applications.
- Updated several Matlab script to process the contact points NetCDF between refinement grids. This will be explained in src:ticket:615.
- Corrected the logic of how the contact grid NetCDF file is processed to load data into structure BRY_CONTACT.
- Fixed a nasty parallel bug in put_refine2d when imposing coarser grid mass flux at the finer grid physical boundaries.
- Added new routine (get_metrics) in nesting.F to process grid spacing metrics on_u and om_v, which are used to impose mass fluxes at the finer grid physical boundaries in refinement applications.
- Added new CPP option ONE_WAY to carry-out one-way nesting in refinement applications. The default is to have two-way nesting.
Additionally, corrected few routines:
- Fixed a bug in ana_m3dobc.h. Few variables are not passed as arguments, so the access is done from the field structures.
- Added logic in inquire.F for better reporting of error messages when the file name is blank (empty).
- Added implicit none to routines in file check_multifile.F and declared a local integer variable. Many thanks to Mark Hadfield for bringing this to my attention.
- Corrected a bug in npzd_iron_inp.h. Used END IF instead of END SELECT. Many thanks to Paul Mattern for reporting this problem.
Change History (1)
comment:1 by , 12 years ago
Resolution: | → Fixed |
Status: | new → closed |
Note:
See TracTickets
for help on using tickets.
