#609 closed upgrade (Done)
Spatially varying Jerlov water type
Component: | Nonlinear | Version: | 3.7 |
Added the option to have spatially varying Jerlov water types for light absorption in the water column. This is used when SOLAR_SOURCE or LMD_SKPP CPP options are activated.
A new CPP option WTYPE_GRID is introduced to activate spatially varying Jerlov water types. The ROMS internal variable Jwtype is now a floating-point variable to facilitate I/O manipulation within the metadata model. The spatially varying Jerlov water type index can be specified in two ways:
- A variable, wtype_grid, in the ROMS GRID NetCDF file:
double wtype_grid(eta_rho, xi_rho) ; wtype_grid:long_name = "Jerlov water type index" ; wtype_grid:coordinates = "lon_rho lat_rho" ;
- or an analytical function in new routine ana_wtype.h, which can be activated with new CPP option ANA_WTYPE. For example, we can have an expression to set the Jerlov water type index in terms of the bathymetry to give a distribution of values between 5 (shallow; turbid water) and 1 (deep; clear water):
fac=1.0/1000.0_r8 ! Inverse bathymetry threshold DO j=JstrT,JendT DO i=IstrT,IendT Jwtype(i,j)=ANINT(5.0_r8-4.5_r8*(TANH(h(i,j)*fac))) ! 1:5 END DO END DO
The variable Jwtype is used in lmd_swfrac to compute the fraction of shortwave flux penetrating the water column (light absorption), modeled as a double exponential decay function in Jerlov water type. The double exponential parameters (lmd_mu1, lmd_mu2, lmd_r1) were also enhanced to add additional Jerlov coastal water types: 1, 3, 5, 7. Currently, the following Jerlow water types are supported:
Array Jerlov Index Water Type Examples ----- ---------- -------- 1 I Open Pacific 2 IA Eastern Mediterranean, Indian Ocean 3 IB Western Mediterranean, Open Atlantic 4 II Coastal waters, Azores 5 III Coastal waters, North Sea 6 1 Skagerrak Strait 7 3 Baltic 8 5 Black Sea 9 7 Coastal waters, dark
The range of indices 1:9 are ordered by increasing absorption: from clear water (type I) to dark turbidity water (type 7). The indices correspond to the paramenters (lmd_mu1, lmd_mu2, lmd_r1) used to model the light absorption into the water column using a double exponential fitting function of (Paulson and Simpson, 1997).
The following figure shows the Jerlov's water type classification based on transmittance along 1 m of seawater:
The water type 9 was not included in the above array classification indices because its double exponential fitting parameters are not available.
I also introduced routine ana_dqdsst.h to specify the surface net heat flux sentivity to SST, d(Q)/d(SST), with analytical expressions (internal ROMS variable dqdt). This is activated with new CPP option ANA_DQDSST. It is now possible to specify the SST in a NetCDF forcing file and the d(Q)/d(SST) field with an analytical function. No longer we need both variables in the NetCDF file.
I haven't coded the function that computes d(Q)/d(SST) using the formula reported in Barnier et al. (1995). Several additional atmospheric field are required (see their equation 6b). The values for d(Q)/d(SST) can be negative or positive and has units of Watts meters-2 Celsius-1 (or internal kinematic units of m/s/Celsius).
If you are planning to use QCORRECTION in your application, I suggest you to read Barnier et al. (1995) paper first. There are some messages in the forum suggesting the summer warming trends cannot be fixed with QCORRECTION. I just tried in the Gulf of Mexico and it worked well. It is just a matter how you specify the appropriate d(Q)/d(SST) values. I usually use monthly composite SST from the NOAA CoastWatch OpenDAP catalog (http://oceanwatch.pfeg.noaa.gov/thredds/catalog.html), see product SST, Blended, Global, EXPERIMENTAL (BA/ssta/mday).
Reference:
Barnier, B., L. Siefridt, and P. Marchesiello, 1995: Thermal forcing for a global ocean circulation model using a three-year climatology of ECMWF analyses, J. Marine Systems, 6, 363-380.
Change History (2)
comment:1 by , 12 years ago
Resolution: | → Done |
Status: | new → closed |
comment:2 by , 12 years ago
