Opened 13 years ago
Closed 13 years ago
#579 closed bug (Fixed)
Corrected logic about tl_LBC
Priority: major Milestone: Adjoint Based Algorithms
Component: Nonlinear Version: 3.6
Keywords: Cc:
Description
Moved the computation of the tl_LBC logical switches from read_phypar.F to inp_par.F to allow the processing of biology and sediment tracers. We need to delay the initialization of these switches because read_BioPar or read_SedPar needs to be called first. In inp_par.F we now have:
#if defined TANGENT || defined TL_IOMS
!  Set lateral boundary condition switches for the tangent linear
!  models (TLM and RPM) to the same values as the adjoint model.
        DO ivar=1,nLBCvar
          DO i=1,4
            tl_LBC(i,ivar,ng)%acquire  =ad_LBC(i,ivar,ng)%acquire
            tl_LBC(i,ivar,ng)%Chapman  =ad_LBC(i,ivar,ng)%Chapman
            tl_LBC(i,ivar,ng)%clamped  =ad_LBC(i,ivar,ng)%clamped
            tl_LBC(i,ivar,ng)%closed   =ad_LBC(i,ivar,ng)%closed
            tl_LBC(i,ivar,ng)%Flather  =ad_LBC(i,ivar,ng)%Flather
            tl_LBC(i,ivar,ng)%gradient =ad_LBC(i,ivar,ng)%gradient
            tl_LBC(i,ivar,ng)%nested   =ad_LBC(i,ivar,ng)%nested
            tl_LBC(i,ivar,ng)%nudging  =ad_LBC(i,ivar,ng)%nudging
            tl_LBC(i,ivar,ng)%periodic =ad_LBC(i,ivar,ng)%periodic
            tl_LBC(i,ivar,ng)%radiation=ad_LBC(i,ivar,ng)%radiation
            tl_LBC(i,ivar,ng)%reduced  =ad_LBC(i,ivar,ng)%reduced
Many thanks to Ha Joon Song for reporting this bug.
I also updated the makefile configuration file Darwin-ifort.mk to avoid warning errors from newer versions of the ifort compiler:
We need to have:
           FFLAGS := -heap-arrays -fp-model source
instead of
           FFLAGS := -heap-arrays -fp-model precise
for Fortran compiling. The precise argument is redundant.
Change History (1)
comment:1 by arango, 13 years ago
Resolution: Fixed
Status: newclosed
