#571 closed request (Done)
set_data.F and friends
Priority: | major | Milestone: | Release ROMS/TOMS 3.6 |
Component: | Nonlinear | Version: | 3.6 |
Added an additional and optional argument SetBC to set_2dfld.F, set_2dfldr.F, set_3dfld.F, and set_3dfldr.F to control the setting of periodic boundary conditions to a particular interpolated field. For example, in set_2dfld.F we now have:
SUBROUTINE set_2dfld_tile (ng, tile, model, ifield, & & LBi, UBi, LBj, UBj, & & Finp, Fout, update, & & SetBC) ... logical, intent(in), optional :: SetBC ... ! ! Set switch to apply boundary conditions. ! IF (PRESENT(SetBC)) THEN LapplyBC=SetBC ELSE LapplyBC=.TRUE. END IF ... ! ! Exchange boundary data. ! IF (update) THEN IF (LapplyBC.and.(EWperiodic(ng).or.NSperiodic(ng))) THEN IF (gtype.eq.r2dvar) THEN CALL exchange_r2d_tile (ng, tile, & & LBi, UBi, LBj, UBj, & & Fout) ELSE IF (gtype.eq.u2dvar) THEN CALL exchange_u2d_tile (ng, tile, & & LBi, UBi, LBj, UBj, & & Fout) ELSE IF (gtype.eq.v2dvar) THEN CALL exchange_v2d_tile (ng, tile, & & LBi, UBi, LBj, UBj, & & Fout) END IF END IF #ifdef DISTRIBUTE IF (.not.LapplyBC) THEN CALL mp_exchange2d (ng, tile, model, 1, & & LBi, UBi, LBj, UBj, & & NghostPoints, & & .FALSE., .FALSE., & & Fout) ELSE CALL mp_exchange2d (ng, tile, model, 1, & & LBi, UBi, LBj, UBj, & & NghostPoints, & & EWperiodic(ng), NSperiodic(ng), & & Fout) END IF #endif END IF
This will facilitate configuring toy problems that require a non-periodic forcing field, say surface air pressure (Pair). Then, in set_data.F we now have:
# if defined BULK_FLUXES || defined ECOSIM || defined ATM_PRESS ! !----------------------------------------------------------------------- ! Set surface air pressure (mb). !----------------------------------------------------------------------- ! # ifdef ANA_PAIR CALL ana_pair (ng, tile, iNLM) # else SetBC=.TRUE. ! SetBC=.FALSE. CALL set_2dfld_tile (ng, tile, iNLM, idPair, & & LBi, UBi, LBj, UBj, & & FORCES(ng)%PairG, & & FORCES(ng)%Pair, & & update, SetBC) IF (exit_flag.ne.NoError) RETURN # endif # endif
The default is set to always apply periodic boundary conditions (SetBC=.TRUE.). The user may edit set_data.F or Build/set_data.f90 to avoid applying periodic boundary conditions (SetBC=.FALSE.).
Many thanks to John Wilkin for requesting this useful capability.
Change History (2)
comment:1 by , 13 years ago
Resolution: | → Done |
Status: | new → closed |
comment:2 by , 13 years ago
