Opened 13 years ago
Closed 13 years ago
#568 closed bug (Fixed)
warning in wrt_info
Reported by: | kate | Owned by: | arango |
Priority: | major | Milestone: | Release ROMS/TOMS 3.6 |
Component: | Nonlinear | Version: | 3.6 |
Trying the Cray compiler:
ioerror=status ftn-7212 crayftn: WARNING WRT_INFO, File = wrt_info.f90, Line = 384 Variable "status" is used before it is defined.
It's true that if a variable is not found, status does not get set, though it does get used. ioerror should get set to a "not found" value instead of to status.
Change History (1)
comment:1 by , 13 years ago
Resolution: | → Fixed |
Status: | new → closed |
Note:
See TracTickets
for help on using tickets.
Indeed, the value for status is not assigned. I am setting ioerror=nf90_enotvar. The parameter nf90_enotvar is the NetCDF error code for Variable not found. Good catch.
