Opened 18 years ago
Closed 18 years ago
#52 closed request (Fixed)
Makefile enhancements
Reported by: | m.hadfield | Owned by: | arango |
Priority: | minor | Milestone: | Release ROMS/TOMS 3.1 |
Component: | Nonlinear | Version: | 3.1 |
Description ¶
Following on from the problems with netcdf.mod & typesize.mod reported in #50 and the proposed solutions, I have come up with a simpler and (I think) better scheme for creating the scratch directory and populating it with the files it needs initially. Since the changes go beyond the scope ot ticket #50, I'm making this a separate ticket.
Modified versions of makefile and Compilers/UNICOS-sn-f90.mk are attached. Changes are:
- File names for netCDF F90 module files are specified via variables NETCDF_MODFILE and TYPESIZES_MODFILE. Default values (netcdf.mod & typesizes.mod) are specified in makefile; these are overridden if necessary in the machine-dependent make file (eg. NETCDF.mod & TYPESIZES.mod for the T3E).
- The netCDF module files are now prerequisites for $(SCRATCH_DIR)/MakeDepend, meaning they will be created at the start of the build process. Rules have been added to make them by copying the originals from $(NETCDF_INCDIR).
- Targets $(SCRATCH_DIR)/MakeDepend, $(SCRATCH_DIR)/$(NETCDF_MODFILE), $(SCRATCH_DIR)/$(TYPESIZES_MODFILE) include $(SCRATCH_DIR) as an order-only prerequisite. Order-only prerequisites are indicated by the pipe ("|") symbol and explained in http://www.gnu.org/software/make/manual/make.html#Prerequisite-Types. If $(SCRATCH_DIR) is made an ordinary prerequisite, then files like $(SCRATCH_DIR)/MakeDepend get re-made every time the directory changes, which is definitely undesirable.
I think the result is quite a bit cleaner than what it replaces.
Change History (3)
by , 18 years ago
by , 18 years ago
Attachment: | UNICOS-sn-f90.mk added |
comment:1 by , 18 years ago
Resolution: | → Fixed |
Status: | new → closed |
I am glad that you were able to build the NetCDF library on the T3E.
Note:
See TracTickets
for help on using tickets.
Machine-dependent file for Cray T3E
