Opened 14 years ago
Closed 14 years ago
#498 closed upgrade (Done)
IMPORTANT: Added test cases to the repository
Priority: | major | Milestone: | Test Cases |
Component: | Test Cases | Version: | 3.4 |
Description ¶
There has been a lot of traffic in the forum of users struggling how to configure the Test Cases distributed in ROMS. Notice that we introduced last year the test svn repository:
URL: https://www.myroms.org/svn/src/test
It includes the sub-directory WC13 showing how to run all the 4D-Var algorithms available in ROMS and documented in WikiROMS tutorial.
Now I adding several directories which include more Test Cases:
test/ DAMEE_4/ /Data/ /netcdf3 /netcdf4 /scoord11 /scoord22 External/ WC13/ /ARRAY_MODES /Data /Functionals /I4DVAR /I4DVAR_impact /Normalization /PSAS /PSAS_impact /PSAS_sensitivity /R4DVAR /R4DVAR_impact /R4DVAR_sensitivity /plotting basin/ benchmark/ bio_toy/ /Data bl_test/ canyon/ double_gyre/ /AFTE /Data /FSV /FTE /Forward /OP /SOsemi estuary_test/ flt_test/ grav_adj/ inlet_test/ /Data kelvin/ lab_canyon/ lmd_test/ riverplume/ seamount/ sed_test/ shoreface/ soliton/ test_chan/ test_head/ /Data upwelling/ weddell/ windbasin/
- Notice that there is a directory for each Test Case. The realistic applications are in uppercase whereas the idealized applications are in lowercase. There is also an External sub-directory containing the metadata files varinfo.dat and coupling.dat.
- Each sub-directory contains the necessary header file, standard input scripts, configuration scripts, and build scripts to compile, link, and run each application.
- All the sub-directories show the build script in all its glory. It provides examples of how to manipulate ROMS c-preprocessing options without the need of changing the makefile and/or application header file. Users can start playing with several combinations of the CPP options. Be aware that when making changes it may require the fine-tuning of the application time-step to satisfy CFL constraint.
Note:
See TracTickets
for help on using tickets.
