Opened 14 years ago
Closed 14 years ago
#487 closed defect (Fixed)
Add boundary call to scale_omega
Reported by: | jcwarner | Owned by: | arango |
Priority: | major | Milestone: | Release ROMS/TOMS 3.4 |
Component: | Nonlinear | Version: | 3.4 |
Can we add a boundary call in scale_omega so that the output of omega is consistent during periodic simulations? When used now, the variable omega (W) is never filled on the outer RHO-points (since it is not used during computations). But for output purposes, especially periodic simulations, it would be nice to see omega be uniform in the along-periodic direction, instead of having zeros along that boundary. This can be accomplished by adding to scale_omega:
1) USE bc_3d_mod, ONLY : bc_w3d_tile 2) ! ! Set lateral boundary conditions. ! CALL bc_w3d_tile (ng, tile, & & LBi, UBi, LBj, UBj, 0, N(ng), & & Wscl)
thanks, -j
Change History (1)
comment:1 by , 14 years ago
Resolution: | → Fixed |
Status: | new → closed |
Summary: | add boundary call to scale_omega → Add boundary call to scale_omega |
Type: | bug → defect |
Note:
See TracTickets
for help on using tickets.
Yes, good catch. This is only needed in periodic boundary condition since the IstrR, IendR, JstrR, JendR ranges are defined differently. So instead, we need:
In non-periodic applications, the values in the outer RHO-points were assigned in routine omega.F. They are rescaled for output purposes in the history NetCDF file.
