Opened 15 years ago
Closed 15 years ago
#483 closed bug (Fixed)
Updated writing of water points, WRITE_WATER option
Priority: major Milestone: Release ROMS/TOMS 3.4
Component: Nonlinear Version: 3.4
Keywords: Cc:
Description
The option to write only water points (WRITE_WATER) in output NetCDF files was updated to account for the recent internal changes to land/sea masking (see src:ticket:476):
  • The call to the wpoints routine is moved from initial to main2d/main3d after the call to set_masks during the initialization step. This is because we need to have the point source modifications to internal land/sea masking arrays (rmask_io and friends) before the waters points counters and indices are computed.
  • The code to compute the water points is changed to correct bug leading to a miscount in periodic boundary applications. Notice that the (IstrR, IendR) and (JstrR, JendR) ranges are different in periodic applications. We need to process interior points and boundary points separately.
  • Notice that the calls to set_masks and wpoints need to be in a separate parallel loops. This is to avoid a serial with partition or shared-memory bug.
  • The masking arrays in output NetCDF headers is changed to pmask_io, rmask_io, umask_io, and vmask_io when either WRITE_WATER or UV_PSOURCE is actiavated. This does not affect ROMS computations because the land/sea masks array pmask, rmask, umask, and vmask are still read from input GRID NetCDF file.
Many thanks to Mathieu Dutour for bringing this to my attention.
Change History (1)
comment:1 by arango, 15 years ago
Resolution: Fixed
Status: newclosed
