Opened 15 years ago
Closed 15 years ago
#478 closed bug (Fixed)
psi mask computation
Reported by: | jcwarner | Owned by: | arango |
Priority: | minor | Milestone: | Release ROMS/TOMS 3.4 |
Component: | Nonlinear | Version: | 3.4 |
During initialization, the mask at PSi_points is recomputed in metrics.F. The range for this is:
DO j=Jstr,Jend DO i=Istr,Iend IF ((rmask... THEN pmask(i,j)=1.0_r8 ... END DO END DO
But the pmask has a range from Istr:Iend+1, and Jstr:Jend+1. So I think this range should be Istr,Iend+1 and Jstr,Jend+1.
Change History (1)
comment:1 by , 15 years ago
Resolution: | → Fixed |
Status: | new → closed |
Note:
See TracTickets
for help on using tickets.
Yes, good catch. However, the I- and J-range needs to be instead:
Notice that periodic boundary conditions and MPI exchange is done after the re-computation for free-slip/no-slip. The Iend+1 and Jend+1 has a different meaning in tiled configurations.
Warning: This change to the code will affect your solution because of a change to the PSI mask at the grid edges.
