Opened 15 years ago
Closed 15 years ago
#475 closed upgrade (Done)
Changed gasdev.F which is used to generate randim numbers
Priority: | major | Milestone: | Release ROMS/TOMS 3.4 |
Component: | Nonlinear | Version: | 3.4 |
Description ¶
Updated couple of routines associated with the floats:
- Changed routine gasdev.F which is used to compute normally-distributed random number sequences. This routine has several F90 constructs that maybe problematic in old compilers. This is obviously a compiler bug. If so, we get usually error in the following expression:
CALL array_copy (PACK(v1(ng:n), mask(ng:n)), v1(ng:), nn, m)
Some compilers either fail to recognize the vector array out of the intrinsic PACK function or its numerical representation even if the routine array_copy is inside of an interface. To avoid this problem, the above statement is replaced by:mc=COUNT(mask(ng:n)) v3(1:mc)=PACK(v1(ng:n), mask(ng:n)) CALL array_copy (v3(1:mc), v1(ng:), nn, m)
Many thanks to first Julio Sheinbaum for reporting this one during the ROMS 4D-Var workshop and recently to Diego Narvaez when trying the floats.
- Corrected an out-of-range computation in grid_coords.F when computing the initial depths for out-of-bounds initial float locations. The following conditional is added:
IF (MyThread(l).and. & & ((DRIFTER(ng)%Tinfo(ixgrd,l).ge.0.5_r8).and. & & (DRIFTER(ng)%Tinfo(iygrd,l).ge.0.5_r8).and. & & (DRIFTER(ng)%Tinfo(ixgrd,l).le. & & REAL(Lm(ng),r8)+0.5_r8).and. & & (DRIFTER(ng)%Tinfo(iygrd,l).le. & & REAL(Mm(ng),r8)+0.5_r8))) THEN ...
Note:
See TracTickets
for help on using tickets.
