#397 closed upgrade (Done)
Added indices to plot term diagnostics
Priority: | major | Milestone: | Plotting Package |
Component: | Plotting | Version: | 3.3 |
Updated plot/Data/varid.dat to include field identification indices for the diagnostic terms in ROMS plotting package. I also made the proper changes to scale and process associated vector fields. The IDs for the new fields are:
[393] DU2DPG 2D U-velocity, Pressure Gradient (cm/s2) [394] DV2DPG 2D V-velocity, Pressure Gradient (cm/s2) *[395] DM2PGV 2D Momentum, Pressure Gradient Vectors (cm/s2) *[396] DM2PGM 2D Momentum, Pressure Gradient Magnitude (cm/s2) *[397] DM2PGS 2D Momentum, Pressure Gradient Streamlines *[398] DM2PGB 2D Momentum, Pressure Gradient Barbs [399] DU2DCO 2D U-velocity, Coriolis (cm/s2) [400] DV2DCO 2D V-velocity, Coriolis (cm/s2) *[401] DM2COV 2D Momentum, Coriolis Vectors (cm/s2) *[402] DM2COM 2D Momentum, Coriolis Magnitude (cm/s2) *[403] DM2COS 2D Momentum, Coriolis Streamlines *[404] DM2COB 2D Momentum, Coriolis Barbs [405] DU2DHA 2D U-velocity, Horizontal Advection (cm/s2) [406] DV2DHA 2D V-velocity, Horizontal Advection (cm/s2) *[407] DM2HAV 2D Momentum, Horizontal Advection Vectors (cm/s2) *[408] DM2HAM 2D Momentum, Horizontal Advection Magnitude (cm/s2) *[409] DM2HAS 2D Momentum, Horizontal Advection Streamlines *[410] DM2HAB 2D Momentum, Horizontal Advection Barbs [411] DU2DSS 2D U-velocity, Surface Stress (cm/s2) [412] DV2DSS 2D V-velocity, Surface Stress (cm/s2) *[413] DM2SSV 2D Momentum, Surface Stress Vectors (cm/s2) *[414] DM2SSM 2D Momentum, Surface Stress Magnitude (cm/s2) *[415] DM2SSS 2D Momentum, Surface Stress Streamlines *[416] DM2SSB 2D Momentum, Surface Stress Barbs [417] DU2DBS 2D U-velocity, Bottom Stress (cm/s2) [418] DV2DBS 2D V-velocity, Bottom Stress (cm/s2) *[419] DM2BSV 2D Momentum, Bottom Stress Vectors (cm/s2) *[420] DM2BSM 2D Momentum, Bottom Stress Magnitude (cm/s2) *[421] DM2BSS 2D Momentum, Bottom Stress Streamlines *[422] DM2BSB 2D Momentum, Bottom Stress Barbs [423] DU2DHV 2D U-velocity, Horizontal Viscosity (cm/s2) [424] DV2DHV 2D V-velocity, Horizontal Viscosity (cm/s2) *[425] DM2HVV 2D Momentum, Horizontal Viscosity Vectors (cm/s2) *[426] DM2HVM 2D Momentum, Horizontal Viscosity Magnitude (cm/s2) *[427] DM2HVS 2D Momentum, Horizontal Viscosity Streamlines *[428] DM2HVB 2D Momentum, Horizontal Viscosity Barbs [429] DU2DHR 2D U-velocity, Horizontal Radiation Stress (cm/s2) [430] DV2DHR 2D V-velocity, Horizontal Radiation Stress (cm/s2) *[431] DM2HRV 2D Momentum, Horizontal Radiation Stress Vectors (cm/s2) *[432] DM2HRM 2D Momentum, Horizontal Radiation Stress Magnitude (cm/s2) *[433] DM2HRS 2D Momentum, Horizontal Radiation Stress Streamlines *[434] DM2HRB 2D Momentum, Horizontal Radiation Stress Barbs [435] DU2DAC 2D U-velocity, Acceleration (cm/s2) [436] DV2DAC 2D V-velocity, Acceleration (cm/s2) *[437] DM2ACV 2D U-velocity, Acceleration Vectors (cm/s2) *[438] DM2ACM 2D U-velocity, Acceleration Magnitude (cm/s2) *[439] DM2ACS 2D U-velocity, Acceleration Streamlines *[440] DM2ACB 2D U-velocity, Acceleration Barbs [441] DU3DPG 3D U-velocity, Pressure Gradient (cm/s2) [442] DV3DPG 3D V-velocity, Pressure Gradient (cm/s2) *[443] DM3PGV 3D Momentum, Pressure Gradient Vectors (cm/s2) *[444] DM3PGM 3D Momentum, Pressure Gradient Magnitude (cm/s2) *[445] DM3PGS 3D Momentum, Pressure Gradient Streamlines *[446] DM3PGB 3D Momentum, Pressure Gradient Barbs [447] DU3DCO 3D U-velocity, Coriolis (cm/s2) [448] DV3DCO 3D V-velocity, Coriolis (cm/s2) *[449] DM3COV 3D Momentum, Coriolis Vectors (cm/s2) *[450] DM3COM 3D Momentum, Coriolis Magnitude (cm/s2) *[451] DM3COS 3D Momentum, Coriolis Streamlines *[452] DM3COB 3D Momentum, Coriolis Barbs [453] DU3DHA 3D U-velocity, Horizontal Advection (cm/s2) [454] DV3DHA 3D V-velocity, Horizontal Advection (cm/s2) *[455] DM3HAV 3D Momentum, Horizontal Advection Vectors (cm/s2) *[456] DM3HAM 3D Momentum, Horizontal Advection Magnitude (cm/s2) *[457] DM3HAS 3D Momentum, Horizontal Advection Streamlines *[458] DM3HAB 3D Momentum, Horizontal Advection Barbs [459] DU3DVA 3D U-velocity, Vertical Advection (cm/s2) [460] DV3DVA 3D V-velocity, Vertical Advection (cm/s2) *[461] DM3VAV 3D Momentum, Vertical Advection Vectors (cm/s2) *[462] DM3VAM 3D Momentum, Vertical Advection Magnitude (cm/s2) *[463] DM3VAS 3D Momentum, Vertical Advection Streamlines *[464] DM3VAB 3D Momentum, Vertical Advection Barbs [465] DU3DHV 3D U-velocity, Horizontal Viscosity (cm/s2) [466] DV3DHV 3D V-velocity, Horizontal Viscosity (cm/s2) *[467] DM3HVV 3D Momentum, Horizontal Viscosity Vectors (cm/s2) *[468] DM3HVM 3D Momentum, Horizontal Viscosity Magnitude (cm/s2) *[469] DM3HVS 3D Momentum, Horizontal Viscosity Streamlines *[470] DM3HVB 3D Momentum, Horizontal Viscosity Barbs [471] DU3DVV 3D U-velocity, Vertical Viscosity (cm/s2) [472] DV3DVV 3D V-velocity, Vertical Viscosity (cm/s2) *[473] DM3VVV 3D Momentum, Vertical Viscosity Vectors (cm/s2) *[474] DM3VVM 3D Momentum, Vertical Viscosity Magnitude (cm/s2) *[475] DM3VVS 3D Momentum, Vertical Viscosity Streamlines *[476] DM3VVB 3D Momentum, Vertical Viscosity Barbs [477] DU3DHR 3D U-velocity, Horizontal Radiation Stress (cm/s2) [478] DV3DHR 3D V-velocity, Horizontal Radiation Stress (cm/s2) *[479] DM3HRV 3D Momentum, Horizontal Radiation Stress Vectors (cm/s2) *[480] DM3HRM 3D Momentum, Horizontal Radiation Stress Magnitude (cm/s2) *[481] DM3HRS 3D Momentum, Horizontal Radiation Stress Streamlines *[482] DM3HRB 3D Momentum, Horizontal Radiation Stress Barbs [483] DU3DVR 3D U-velocity, Vertical Radiation Stress (cm/s2) [484] DV3DVR 3D V-velocity, Vertical Radiation Stress (cm/s2) *[485] DM3VRV 3D Momentum, Vertical Radiation Stress Vectors (cm/s2) *[486] DM3VRM 3D Momentum, Vertical Radiation Stress Magnitude (cm/s2) *[487] DM3VRS 3D Momentum, Vertical Radiation Stress Streamlines *[488] DM3VRB 3D Momentum, Vertical Radiation Stress Barbs [489] DU3DAC 3D U-velocity, Acceleration (cm/s2) [490] DV3DAC 3D V-velocity, Acceleration (cm/s2) *[491] DM3ACV 3D U-velocity, Acceleration Vectors (cm/s2) *[492] DM3ACM 3D U-velocity, Acceleration Magnitude (cm/s2) *[493] DM3ACS 3D U-velocity, Acceleration Streamlines *[494] DM3ACB 3D U-velocity, Acceleration Barbs [495] DTEMHA Temperature, Horizontal Advection (Celsius/s) [496] DTEMVA Temperature, Vertical Advection (Celsius/s) [497] DTEMVD Temperature, Vertical Diffusion (Celsius/s) [498] DTEMAC Temperature, Time Rate of Change (Celsius/s) [499] DSALHA Salinity, Horizontal Advection (1/s) [500] DSALVA Salinity, Vertical Advection (1/s) [501] DSALVD Salinity, Vertical Diffusion (1/s) [502] DSALAC Salinity, Time Rate of Change (1/s) [503] DNO3HA Nitrate, Horizontal Advection (mmol/m3/s) [504] DNO3VA Nitrate, Vertical Advection (mmol/m3/s) [505] DNO3VD Nitrate, Vertical Diffusion (mmol/m3/s) [506] DNO3AC Nitrate, Time Rate of Change (mmol/m3/s) [507] DNH4HA Ammonium, Horizontal Advection (mmol/m3/s) [508] DNH4VA Ammonium, Vertical Advection (mmol/m3/s) [509] DNH4VD Ammonium, Vertical Diffusion (mmol/m3/s) [510] DNH4AC Ammonium, Time Rate of Change (mmol/m3/s) [511] DPONHA Particulate Organic Nitrogen, Horizontal Advection (mmol/m3/ [512] DPONVA Particulate Organic Nitrogen, Vertical Advection (mmol/m3/s) [513] DPONVD Particulate Organic Nitrogen, Vertical Diffusion (mmol/m3/s) [514] DPONAC Particulate Organic Nitrogen, Time Rate of Change (mmol/m3/s [515] DDONHA Dissolved Organic Nitrogen, Horizontal Advection (mmol/m3/s) [516] DDONVA Dissolved Organic Nitrogen, Vertical Advection (mmol/m3/s) [517] DDONVD Dissolved Organic Nitrogen, Vertical Diffusion (mmol/m3/s) [518] DDONAC Dissolved Organic Nitrogen, Time Rate of Change (mmol/m3/s) [519] DSILHA Silica, Horizontal Advection (mmol/m3/s) [520] DSILVA Silica, Vertical Advection (mmol/m3/s) [521] DSILVD Silica, Vertical Diffusion (mmol/m3/s) [522] DSILAC Silica, Time Rate of Change (mmol/m3/s) [523] DOPAHA Particulate Organic Silica, Horizontal Advection (mmol/m3/s) [524] DOPAVA Particulate Organic Silica, Vertical Advection (mmol/m3/s) [525] DOPAVD Particulate Organic Silica, Vertical Diffusion (mmol/m3/s) [526] DOPAAC Particulate Organic Silica, Time Rate of Change (mmol/m3/s) [527] DDFEHA Available Dissolved Iron, Horizontal Advection (mmol/m3/s) [528] DXXXVA Available Dissolved Iron, Vertical Advection (mmol/m3/s) [529] DXXXVD Available Dissolved Iron, Vertical Diffusion (mmol/m3/s) [530] DXXXAC Available Dissolved Iron, Time Rate of Change (mmol/m3/s) [531] DCHLHA Chlorophyll, Horizontal Advection (mmol/m3/s) [532] DCHLVA Chlorophyll, Vertical Advection (mmol/m3/s) [533] DCHLVD Chlorophyll, Vertical Diffusion (mmol/m3/s) [534] DCHLAC Chlorophyll, Time Rate of Change (mmol/m3/s) [535] DPHYHA Phytoplankton, Horizontal Advection (mmol/m3/s) [536] DPHYVA Phytoplankton, Vertical Advection (mmol/m3/s) [537] DPHYVD Phytoplankton, Vertical Diffusion (mmol/m3/s) [538] DPHYAC Phytoplankton, Time Rate of Change (mmol/m3/s) [539] DPFEHA Phytoplankton-Fe, Horizontal Advection (mmol/m3/s) [540] DPFEVA Phytoplankton-Fe, Vertical Advection (mmol/m3/s) [541] DPFEVD Phytoplankton-Fe, Vertical Diffusion (mmol/m3/s) [542] DPFEAC Phytoplankton-Fe, Time Rate of Change (mmol/m3/s) [543] DNPHHA Nanophytoplankton, Horizontal Advection (mmol/m3/s) [544] DNPHVA Nanophytoplankton, Vertical Advection (mmol/m3/s) [545] DNPHVD Nanophytoplankton, Vertical Diffusion (mmol/m3/s) [546] DNPHAC Nanophytoplankton, Time Rate of Change (mmol/m3/s) [547] DDIAHA Diatom, Horizontal Advection (mmol/m3/s) [548] DDIAVA Diatom, Vertical Advection (mmol/m3/s) [549] DDIAVD Diatom, Vertical Diffusion (mmol/m3/s) [550] DDIAAC Diatom, Time Rate of Change (mmol/m3/s) [551] DZOOHA Zooplankton, Horizontal Advection (mmol/m3/s) [552] DZOOVA Zooplankton, Vertical Advection (mmol/m3/s) [553] DZOOVD Zooplankton, Vertical Diffusion (mmol/m3/s) [554] DZOOAC Zooplankton, Time Rate of Change (mmol/m3/s) [555] DMIZHA Microzooplankton, Horizontal Advection (mmol/m3/s) [556] DMIZVA Microzooplankton, Vertical Advection (mmol/m3/s) [557] DMIZVD Microzooplankton, Vertical Diffusion (mmol/m3/s) [558] DMIZAC Microzooplankton, Time Rate of Change (mmol/m3/s) [559] DMEZHA Mesozooplankton, Horizontal Advection (mmol/m3/s) [560] DMEZVA Mesozooplankton, Vertical Advection (mmol/m3/s) [561] DMEZVD Mesozooplankton, Vertical Diffusion (mmol/m3/s) [562] DMEZAC Mesozooplankton, Time Rate of Change (mmol/m3/s) [563] DPRZHA Predactor Zooplankton, Horizontal Advection (mmol/m3/s) [564] DPRZVA Predactor Zooplankton, Vertical Advection (mmol/m3/s) [565] DPRZVD Predactor Zooplankton, Vertical Diffusion (mmol/m3/s) [566] DPRZAC Predactor Zooplankton, Time Rate of Change (mmol/m3/s) [567] DDETHA Detritus, Horizontal Advection (mmol/m3/s) [568] DDETVA Detritus, Vertical Advection (mmol/m3/s) [569] DDETVD Detritus, Vertical Diffusion (mmol/m3/s) [570] DDETAC Detritus, Time Rate of Change (mmol/m3/s) [571] DSDNHA Small Detritus-N, Horizontal Advection (mmol/m3/s) [572] DSDNVA Small Detritus-N, Vertical Advection (mmol/m3/s) [573] DSDNVD Small Detritus-N, Vertical Diffusion (mmol/m3/s) [574] DSDNAC Small Detritus-N, Time Rate of Change (mmol/m3/s) [575] DLDNHA Large Detritus-N, Horizontal Advection (mmol/m3/s) [576] DLDNVA Large Detritus-N, Vertical Advection (mmol/m3/s) [577] DLDNVD Large Detritus-N, Vertical Diffusion (mmol/m3/s) [578] DLDNAC Large Detritus-N, Time Rate of Change (mmol/m3/s) [579] DSDCHA Small Detritus-C, Horizontal Advection (mmol/m3/s) [580] DSDCVA Small Detritus-C, Vertical Advection (mmol/m3/s) [581] DSDCVD Small Detritus-C, Vertical Diffusion (mmol/m3/s) [582] DSDCAC Small Detritus-C, Time Rate of Change (mmol/m3/s) [583] DLDCHA Large Detritus-C, Horizontal Advection (mmol/m3/s) [584] DLDCVA Large Detritus-C, Vertical Advection (mmol/m3/s) [585] DLDCVD Large Detritus-C, Vertical Diffusion (mmol/m3/s) [586] DLDcAC Large Detritus-C, Time Rate of Change (mmol/m3/s) [587] DTICHA Total Inorganic Carbon, Horizontal Advection (mmol/m3/s) [588] DTICVA Total Inorganic Carbon, Vertical Advection (mmol/m3/s) [589] DTICVD Total Inorganic Carbon, Vertical Diffusion (mmol/m3/s) [590] DTICAC Total Inorganic Carbon, Time Rate of Change (mmol/m3/s) [591] DALKHA Alkalinity, Horizontal Advection (mmol/m3/s) [592] DALKVA Alkalinity, Vertical Advection (mmol/m3/s) [593] DALKVD Alkalinity, Vertical Diffusion (mmol/m3/s) [594] DALKAC Alkalinity, Time Rate of Change (mmol/m3/s) [595] DOXYHA Oxygen, Horizontal Advection (mmol/m3/s) [596] DOXYVA Oxygen, Vertical Advection (mmol/m3/s) [597] DOXYVD Oxygen, Vertical Diffusion (mmol/m3/s) [598] DOXYAC Oxygen, Time Rate of Change (mmol/m3/s) [599] DDENHA Denitrification, Horizontal Advection (mmol/m2/s) [600] DDENVA Denitrification, Vertical Advection (mmol/m2/s) [601] DDENVD Denitrification, Vertical Diffusion (mmol/m2/s) [602] DDENAC Denitrification, Time Rate of Change (mmol/m2/s) [603] DNUPHA Averaged NO3 Uptake (mmol/m3/day) [604] DPPRVA Averaged Primary Production (mmol/m3/day) [605] DO2ASF Averaged O2 air-sea Flux (mmol/m2/day) [606] DCO2AF Averaged CO2 air-sea Flux (mmol/m2/day) [607] DPPCO2 Averaged Partial Pressure of CO2 (microatm)
Many thanks to Kate Hedstrom for bringing this to my attention.
I also updated Copyright label so mostly all the files were changed.
Change History (2)
comment:1 by , 16 years ago
Resolution: | → Done |
Status: | new → closed |
comment:2 by , 16 years ago
Milestone: | Release ROMS/TOMS 3.3 → Plotting Package |
Note:
See TracTickets
for help on using tickets.
