Opened 16 years ago
Closed 16 years ago
#339 closed bug (Fixed)
Incorrect logic in get_ngfld
Priority: | major | Milestone: | Release ROMS/TOMS 3.3 |
Component: | Nonlinear | Version: | 3.3 |
Warning: This is a very important fix when your input files are not CF compliant. Recall that get_ngfld is used to process boundary, river, and tide data.
Corrected a bug in file get_ngfld.F around line 193. We need to use n_vdim instead of n_dim in the DO loop:
! ! If Nrec=0, input file is not CF compliant, check variable dimension ! to see if the dimension contains the "time" string. ! IF (got_time.and.(Nrec.eq.0)) THEN DO i=1,n_vdim IF (INDEX(TRIM(var_Dname(i)),'time').ne.0) THEN Nrec=var_Dsize(i) END IF END DO END IF
This only occurs when input file is not CF compliant with the time dimension. In the previous versions you will get an out of bounds error for variable var_Dname.
I also updated several of the CDL files to be CF compliant.
Change History (1)
comment:1 by , 16 years ago
Resolution: | → Fixed |
Status: | new → closed |
Note:
See TracTickets
for help on using tickets.
