Opened 16 years ago
Closed 16 years ago
#332 closed upgrade (Done)
Update to makefile, build and compilation scripts
Priority: | major | Milestone: | Release ROMS/TOMS 3.3 |
Component: | Nonlinear | Version: | 3.3 |
Description
The makefile was updated so the COMPILERS definition may be specified in either the build.sh or build.bach scripts. This allows the user to specify a customized version (different path) of the configuration files (*.mk) that are distributed in Compilers subdirectory. The makefile has now the following statement to facilitate such operation:
COMPILERS ?= $(CURDIR)/Compilers MAKE_MACROS := $(COMPILERS)/make_macros.mk
so we can set the COMPILERS definition with an environmental variable in build.sh:
setenv COMPILERS ${MY_ROMS_SRC}/Compilers
or you may use a copy of Linux-ifort.mk, for example, in your project directory:
setenv COMPILERS ${MY_PROJECT_DIR}
If you are using this strategy, make sure that you keep the make configuration scripts up-to-date.
I also modified Compilers/Linux-ifort.mk and Compilers/Darwin-ifort.mk files to use precise (IEEE) floating-point operations: -fp-model precise
FFLAGS := -heap-arrays -fp-model precise
I was completely surprised with the -ip option in ifort which triggers a less precise operation to speed the computation during optimization. I even get different results when I ran the same executable again and again. This must be a bug in ifort 11. Also, I was not longer to check for parallel bugs by comparing output NetCDF files in serial and parallel. I have a lot of roundoff in all fields everywhere. This is very annoying...
