Opened 17 years ago
Closed 17 years ago
#272 closed upgrade (Fixed)
Updated parallel I/O to support read/write of water points only
Priority: | major | Milestone: | Parallel Input/Output |
Component: | Parallelism | Version: | 3.2 |
Description ¶
Updated the parallel I/O to support READ_WATER and WRITE_WATER C-preprocessing options. This was very tricky to implement. I have been thinking about this for several days. I finally came up with a cheap solution for this task in parallel I/O.
It is working very nicely now including the PERFECT_RESTART option which requires using nf_fread4d and nf_fwrite4d.
Change History (4)
comment:1 by , 17 years ago
Resolution: | → Done |
Status: | new → closed |
Summary: | Update parallel I/O to support read/write of water points only → Updated parallel I/O to support read/write of water points only |
comment:2 by , 17 years ago
Resolution: | Done |
Status: | closed → reopened |
comment:3 by , 17 years ago
comment:4 by , 17 years ago
Resolution: | → Fixed |
Status: | reopened → closed |
Note:
See TracTickets
for help on using tickets.
Oops, I forgot to change couple of things back in distribute.F and nf_fwrite2d.F. I was playing with these two routines during my last update to the parallel I/O. I actually correcting the declaration of Aout in mp_gather2d and mp_gather3d. It should be declared as:
since it can be dimension differently with the INLINE_2DIO.
