Opened 17 years ago
Closed 16 years ago
#269 closed bug (Fixed)
Tidal forcing data not being read from forcing file
Reported by: | m.hadfield | Owned by: | arango |
Priority: | major | Milestone: | Release ROMS/TOMS 3.2 |
The recent IO updates appear to have broken a tidally-forced application of mine. The tidal period and parameters (elevation amplitude, etc) are not being read from the file, as illustrated by the following output:
GET_NGFLD - tidal period (Min = 3.11285267-303 Max = 3.11285267-303) GET_2DFLD - tidal elevation amplitude (Min = 1.00000000E+37 Max = -1.00000000E+37) GET_2DFLD - tidal elevation phase angle (Min = 1.00000000E+37 Max = -1.00000000E+37)
The problem seems to be that in ROMS/Nonlinear/get_idata.F at line 101, NTC(ng) (i.e. the number of tidal consttituents) is set to 0
IF (iic(ng).eq.0) THEN NTC(ng)=0 CALL get_ngfld (ng, iNLM, idTper, ncFRCid(idTper,ng), & & nFfiles(ng), FRCname(1,ng), update(1), & & 1, MTC, 1, 1, 1, NTC(ng), 1, & & TIDES(ng) % Tperiod(1)) # if defined AVERAGES_DETIDE && (defined SSH_TIDES || defined UV_TIDES) TIDEname(ng)=TRIM(ncfile) # endif END IF
and it never acquires any other value. (In my application it should be 1.) Therefore all the subsequent read requests return 0 data values.
As an ad hoc fix, setting NTC(ng) to 1 in get_idata.F causes sensible tidal forcing data to be read from the file
GET_NGFLD - tidal period (Min = 4.47141632E+04 Max = 4.47141632E+04) GET_2DFLD - tidal elevation amplitude (Min = 9.37254056E-02 Max = 1.37402248E+00) GET_2DFLD - tidal elevation phase angle (Min = 2.47094957E+00 Max = 5.79200999E+00)
I don't know how NTC(ng) should get its value, however.
Change History (1)
comment:1 by , 16 years ago
Resolution: | → Fixed |
Status: | new → closed |
Yes, good catch! I fixed this logic in a more robust way by inquiring the number of tidal constituents for all nested grids in mod_tides.F. I cleaned get_idata.F to use the parallel interface of mod_netcdf.F. Similar logic is done in mod_sources.F to inquire the number of point sources Nsrc(ng) from input NetCDF file.
I also corrected a parallel bug in inp_par.F when either W4DVAR or W4DPSAS is activated. The nTLM(ng)=nHIS(ng) was inside of a code that it is only executed by the master thread. Many thanks to Brian Powell for reporting this problem.
