Opened 17 years ago
Closed 17 years ago
#267 closed bug (Fixed)
boundary condition changes
Reported by: kate Owned by: arango
Priority: minor Milestone: Release ROMS/TOMS 3.2
Keywords: Cc:
set_tides fails to compile because mod_boundary has tests on NORTH_FSOBC for the definition of zeta_north, but set_tides doesn't have this test. I have a NORTHERN_WALL, so get:
 PGF90-S-0142-zeta_north is not a member of this RECORD (set_tides.f90: 60)
 PGF90-S-0142-ubar_north is not a member of this RECORD (set_tides.f90: 60)
 PGF90-S-0142-vbar_north is not a member of this RECORD (set_tides.f90: 60)
Change History (3)
Description: modified (diff)
Resolution: Fixed
Status: newclosed
Yes, we need to add the CPP conditionals here. It turns out that my test have four open boundaries so I didn't catch this bug.
comment:2 by ocecept, 17 years ago
Resolution: Fixed
Status: closedreopened
After the last revision (297) I have the same problem above. When using ana_fsobc and ana_m2obc with NOTHERN_WALL, get:
fortcom: Error: analytical.f90, line 136: This is not a field name that is defined in the encompassing structure. [ZETA_NORTH]
BOUNDARY(ng)%zeta_north(i)=0.0_r8
fortcom: Error: analytical.f90, line 433: This is not a field name that is defined in the encompassing structure. [UBAR_NORTH]
BOUNDARY(ng)%ubar_north(i)=0.0_r8
fortcom: Error: analytical.f90, line 436: This is not a field name that is defined in the encompassing structure. [VBAR_NORTH]
BOUNDARY(ng)%vbar_north(i)=0.0_r8
compilation aborted for analytical.f90 (code 1)
comment:3 by arango, 17 years ago
Resolution: Fixed
Status: reopenedclosed
Yes, thank you. I missed this one in ana_fsobc.h. I did took care of the others routines ana_m2obc.h, ana_m3obc.h, and ana_tobc.h when I made this update.
I also corrected missing RPM_RELAXATION conditional in w4dvar_ocean.h. Many thanks to Brian Powell for reporting this problem.
