Opened 17 years ago
Closed 17 years ago
#259 closed bug (Fixed)
Corrected bug in wrt_impulse.F
Component: | Adjoint | Version: | 3.2 |
Description
The local variable Iinp was not assigned in routine wrt_impulse.F.
Also corrected a problem in build.bash when the macro definitions are commented out. We need to add a colon when testing if the macro expands to NULL:
We need to use:
if [ -n "${USE_MPIF90:+1}" ]; then ... fi
indead of
if [ -n "${USE_MPIF90+1}" ]; then ... fi
Many thanks to David Robertson for fixing this problem.
Note:
See TracTickets
for help on using tickets.
