Opened 17 years ago
Closed 17 years ago
#239 closed defect (Fixed)
float track indices
Reported by: kate Owned by: arango
Priority: minor Milestone: Release ROMS/TOMS 3.2
Keywords: Cc:
In mod_param.F, NFV is dimensioned by 10+NT or 12+NT, depending. Later, in step_floats.F, the two optional values are overwritten by tracers, plus it is assumed in wrt_floats.F that the tracers are after position 10. It seems to me you need to get that 10/12 thing to propagate into step_floats.F so that the vertical mixing can be output if desired.
Change History (1)
Description: modified (diff)
Resolution: Fixed
Status: newclosed
Yes, That's a possibility.
