Opened 17 years ago
Closed 17 years ago
#234 closed bug (Fixed)
Pointer association in nf_fread*d routines
Priority: | major | Milestone: | Release ROMS/TOMS 3.2 |
It turns out that we need to follow the point association rules for array IJwater in the call to mp_scatter in input routines nf_fread2d.F, nf_fread3d.F, and nf_fread4d.F when the READ_WATER option is activated. Although these input routines are not inside a module, the mp_scatter routine is and this array is passed as a pointer using the SCALARS(ng)%IJwater synthax. This problem is also found in routine white_noise.F.
This is similar to src:ticket:228 and discovered using ifort 10.1. Many thanks to Mathieu Dutour for reporting this problem.
Change History (1)
comment:1 by , 17 years ago
Resolution: | → Fixed |
Status: | new → closed |
Note:
See TracTickets
for help on using tickets.
