Opened 17 years ago
Closed 17 years ago
#219 closed bug (Fixed)
Coefficients not initialised in step_floats.F
Reported by: | m.hadfield | Owned by: | arango |
Priority: | major | Milestone: | Release ROMS/TOMS 3.2 |
Description ¶
In step_floats.F, the following code (lines 278-286)...
! ! Compute vertical position (grid units) 3D Lagrangian floats. ! IF (Ftype(l).eq.flt_Lagran) THEN track(izgrd,nfp1,l)=cff1*track(izgrd,nf ,l)- & & cff2*track(izgrd,nfm2,l)+ & & dt(ng)*(cff3*track(izrhs,nfp1,l)+ & & cff4*track(izrhs,nf ,l)- & & cff3*track(izrhs,nfm1,l))
...uses coefficients cff1, cff2, cff3 and cff4. However cff3 and cff4 have not been initialised, and cff1 and cff2 have values 8/3 and 4/3 (assigned to them at lines 264-265) which don't look right in this expression.
The effect of the uninitialised values is platform-dependent: on a Cray T3E it causes the model to crash.
Change History (2)
comment:1 by , 17 years ago
comment:2 by , 17 years ago
Resolution: | → Fixed |
Status: | new → closed |
Yes, good catch. I copied and pasted the wrong piece of code.
Note:
See TracTickets
for help on using tickets.
PS: the new code with the uninitialised coefficients appears to have been introduced at revision 237, in response to ticket 209.
