Opened 18 years ago
Closed 18 years ago
#104 closed bug (Fixed)
combo of LMD and WET_DRY blows up
Reported by: | kate | Owned by: | arango |
Priority: | major | Milestone: | Release ROMS/TOMS 3.1 |
Component: | Nonlinear | Version: | 3.1 |
Question about this code in step2d:
# if defined WET_DRY && defined MASKING zeta(i,j,knew)=zeta(i,j,knew)+ & & (Dcrit(ng)-h(i,j))*(1.0_r8-rmask(i,j)) # endif
Do you really want to do this inside the land mask or just inside the rmask_wet? It causes trouble in the LMD_SKPP inside the land mask when h is big (say 312m). It leads to a wacky computation of the light at the bottom of the mixed layer if zeta=-312. If this is indeed correct, I would advocate setting h to hmin inside the land mask after it is read in.
Attachments (1)
Change History (3)
by , 18 years ago
comment:2 by , 18 years ago
comment:3 by , 18 years ago
Resolution: | → Fixed |
Status: | new → closed |
Note:
See TracTickets
for help on using tickets.
I attached a patch which is one solution for making things work with both WET_DRY and KPP.
