Where to find the function "tar"
eastwind111
#1 Unread post by eastwind111 »
Hi, everyone.
I met another question when I tried to install the ROMS.
After I installed Cygwin and tried to install g95, I didn't have the function "g95" in my pc, so I can't carry out this command, "tar -xvzf g95-x86-cygwin.tgz.tar"
Anyone could help me?
Tar is an old, old Unix utility. Here's the gnu version: http://www.gnu.org/software/tar/
m.hadfield
It may be that you don't have tar installed, in which case you can install it with Cygwin setup.
The more likely problem is that the file name you give, "g95-x86-cygwin.tgz.tar" has a redundant ".tar" on the end. This was probably added by Internet Explorer during the download. Rename it "g95-x86-cygwin.tgz" and try again.
Be warned that there are a few more non-trivial steps to do before you can build a ROMS application. The ones I can think of off-hand are:
  • Once you have g95 working with Cygwin, you will need to build the netCDF library from source and install it.
  • You will need to install Perl (via Cygwin setup) in order to run the cpp_clean script.
