Python build script
hetland
Python build script
#1 Unread post by hetland »
Inspired by some of the other build scripts I have seen using either the C shell or bash, I have made a python script that does the same. I feel the advantage of this script is that the options are more flexible -- it is easier to have more logic in a real programing language than a shell script.
#!/usr/bin/env python
# encoding: utf-8
build_roms.py
Created by Rob Hetland on 2008-03-31.
Copyright (c) 2008 Texas A&M Univsersity. All rights reserved.
Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the “Software”), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
import sys
import os
import getopt
help_message = '''
build-roms.py is a script used to build the Regional Ocean Modeling System
Usage:
    build-roms.py [options] ROMS_APPLICATION
The ROMS_APPLICATION, the sole argument to the script, must be either specified
on the command line, or present as an environmental variable.  If present, the
argument will override the environmental variable.
Options:
    -h, --help        Print this message
    --fort=[ifort]    Specify fortran compiler
    --netcdf=[4, 3]   Version of NetCDF to use [default is NetCDF4]
    -j=n              Parallel make [n = number of procs, default is 4]
    --mpi             Compile using mpi
    --clean           Delete Build scratch directory before build
    --debug           Compile in debug mode
    --root            Specify ROMS_ROOT_DIR
Default values can be taken from environmental variables, if present.  Command
line options always override defaults.  Environmental variables are:
    FORT            for fortran compiler, overriden by --fort
    ROMS_ROOT_DIR   for ROMS root directory, overriden by --root
class Usage(Exception):
    def __init__(self, msg):
        self.msg = msg
def main(argv=None):
    if argv is None:
        argv = sys.argv
    try:
        try:
            opts, args = getopt.getopt(argv[1:], "hj", \
                         ["help", "mpi", "fort=", "netcdf=", "debug", "clean", "root"])
        except getopt.error, msg:
            raise Usage(msg)
        # Get default values from environment, if present
        if os.environ.has_key('ROMS_ROOT_DIR'):
            ROMS_ROOT_DIR = os.environ['ROMS_ROOT_DIR']
        else:
            ROMS_ROOT_DIR=os.path.join(os.environ['HOME'], 'ROMS')
        USE_MPI=''
        USE_MPIF90=''
        USE_DEBUG=''
        USE_LARGE='on'
        if os.environ.has_key('FORT'):
            FORT = os.environ['FORT']
        else:
            FORT='ifort'
        USE_NETCDF4='on'
        NP=4
        # option processing
        for option, value in opts:
            if option in ("-h", "--help"):
                raise Usage(help_message)
            if option == "--mpi":
                USE_MPI = 'on'
                USE_MPI90 = 'on'
            if option == "--fort":
                FORT=value
            if option == "--netcdf":
                if value != '4':
                    USE_NETCDF4=''
            if option == "--root":
                ROMS_ROOT_DIR=value
            if option == "--debug":
                USE_DEBUG = 'on'
            if option == "-j":
                NP = value
            if option == "--clean":
                print 'Removing Build directory...'
                os.system('rm -rf Build')
        if os.environ.has_key('ROMS_APPLICATION'):
            ROMS_APPLICATION = os.environ['ROMS_APPLICATION'].upper()
        else:
            assert len(args) == 1, 'ERROR: Must specify ROMS_APPLICATION'
        if len(args) == 1:
            ROMS_APPLICATION=args[0].upper()
        headerfile = ROMS_APPLICATION.lower() + '.h'
        assert os.path.exists(headerfile), \
            'ERROR: header file %s does not exist' % headerfile
    except Usage, err:
        print >> sys.stderr, sys.argv[0].split("/")[-1] + ": " + str(err.msg)
        return 2
    MY_PROJECT_DIR=os.getcwd()
    MY_HEADER_DIR=MY_PROJECT_DIR
    MY_ANALYTICAL_DIR=os.path.join(MY_PROJECT_DIR,'Functionals')
    BINDIR=MY_PROJECT_DIR
    SCRATCH_DIR=os.path.join(MY_PROJECT_DIR,'Build')
    ENV_STR = 'ROMS_APPLICATION=%s FORT=%s USE_MPI=%s USE_MPIF90=%s USE_NETCDF4=%s USE_DEBUG=%s USE_LARGE=%s MY_HEADER_DIR=%s MY_ANALYTICAL_DIR=%s BINDIR=%s SCRATCH_DIR=%s' % (ROMS_APPLICATION, FORT, USE_MPI, USE_MPIF90, USE_NETCDF4, USE_DEBUG, USE_LARGE, MY_HEADER_DIR, MY_ANALYTICAL_DIR, BINDIR, SCRATCH_DIR)
    print ENV_STR.replace(' ', '\n')
    os.system("cd %s ; %s make -j %s" % (ROMS_ROOT_DIR, ENV_STR, NP))
if __name__ == "__main__":
    sys.exit(main())
Did you included the full build script? Please send me a copy of your script to my regular e-mail. I will add this script to the svn repository.
Thanks, :D
