Ken Coyle and I are trying to solve an issue in the tracer timestepping. I posted about it on the ROMS blog, but still haven't figured it out. Apparently, the t(nnew) value at the point in the timestepping in which the biology is computed has a value that's temperature*Hz. However, when the water gets shallow, there's got to be more to it than that:
t(nnew) = 0.2405811213519759
Hz = 6.26551716187506713E-3
t(nnew)/Hz = 38.397647813636787 (Temperature as seen by biology)
The other timelevel of t is 0.48, more reasonable for a Bristol Bay wintertime temperature. Ken is searching for temperatures that get above 35 (rather than simply clamping as some biology options do). The surface elevation is -11.216 and h is 11.479, making for very shallow water, but the wet/dry mask is still showing wet.
Can someone explain what is going on here and what we should do about it? I don't see clamping as a viable option since temperatures of 35 in the winter are still going to produce erroneous growth rates.
Tracer timestepping question
Re: Tracer timestepping question
Hello Kate,
I wonder has the problem you reported above been solved or not? Now I deal with a similar one being puzzled about unrealistic temperature values (~50C) when I read t(nnew) instead of t(nstp) in my npzd-type model.
Andrey
Andrey
We "solved" it by increasing the bottom drag in an experimental way so that the water depth doesn't get that drastically shallow. It also allows us to turn off the WET_DRY option. We still get the occasional blow up which can be gotten over by shortening the timestep for some while (which also increases the maximum drag allowed).
