array scalars%sc_w is out of range?
FengZhou
#1 Unread post by FengZhou »
Hi, all,
I just tried ROMS3 and compiled the codes successfully with Upwelling case and a realistic case. But there is an error during executing the latter. The message is :
0: Subscript out of range for array scalars%sc_w (set_scoord.f90: 49)
subscript=0, lower bound=0, upper bound=-1, dimension=1
my set-up is
4.000 Tcline S-coordinate surface/bottom layer width (m) used
While in ROMS2.2, there is no such error.
Do you have any clue?
Thanks in advance!
zhou
ROMS 3 needs you to specify the grid dimensions in the input file: Lm, Mm, and N. What do you have for N?
FengZhou
#3 Unread post by FengZhou »
hi,Kate,
Thanks for your reply.
My grid dimension is as following( need only to input into External/byesea.h in Roms3 ?):
Lm == 167 ! Number of I-direction INTERIOR RHO-points
Mm == 243 ! Number of J-direction INTERIOR RHO-points
N == 30 ! Number of vertical levels
while in ROMS2, they were written in Modules/mod_param.F, right?
hmin = 8
hmax= 2500
zhou
This wasn't the PGI compiler, was it? I had something like that happen to me, where it forgot about the allocated memory. Anyone have a clue?
FengZhou
#5 Unread post by FengZhou »
Yes, I use PGI compiler.
zhang
#6 Unread post by zhang »
which version of pgi are you using?
#7 Unread post by kate »
I have PGI 7.0.2 and see this with my most complex domain. Upwelling runs fine, as do all three sizes of Benchmark. Sorry I haven't pushed on it further, but we've had Pathscale and Sunstudio longer and I've got other issues to solve. In the debugger, I can see the memory for scalars%sc_w where it gets allocated, then it's not there later, when trying to write to it the first time.
FengZhou
#8 Unread post by FengZhou »
zhang wrote:which version of pgi are you using?
my pgi is 7.0.3.
other information:
Wednesday - January 30, 2008 - 3:19:38 PM
Bohai-YellowSea-EastChinaSea, 1/12 degree
Operating system : Linux
CPU/hardware : i686
Compiler system : pgi
Compiler command : mpif90
Compiler flags : -g -C -Mfree
FengZhou
#9 Unread post by FengZhou »
Hi, all,
problem is probably fixed. I forgot to define the nudging block for the realistic case. Its running just by undefining the nudging items. Now I am tracking on...
Thank you all.
