Light attenuation in Fasham
LauraB
#1 Unread post by LauraB »
Hello all,
My question now is about light attenuation, which is given by an exponential: exp[-(kw + kchl . CHL) z],
where CHL is the integrated chlorophyll concentration in the column from surface to level z.
In BioFasham.in, kchl (AttChl) is given in units of 1/(mgChl m^2). In the code, the computation of light attenuation is
Att=EXP(-0.5_r8*(AttSW(ng)+AttChl(ng)*Bio(i,k,iChlo))*  &
     &                  (z_w(i,j,k)-z_w(i,j,k-1)))
Bio(i,k,iChlo) units should be mgChl*m, and should represent the integrated chlorophyll in a grid cell... Does Bio(i,k,iChlo) have these characteristics? As far as I understand fasham.h, Bio(i,k,iChlo) is chlorophyll in mg/m^3 (somewhere a comment says that "all the tracer at input have transport units: m Tunits....", and then creates Bio(i,k,indx) by dividing by Hz)
Thanks a lot for the input,
Laura
kfennel
#2 Unread post by kfennel »
Hi Laura,
In the equation exp[-(kw + kchl . CHL) z] CHL represents the mean chlorophyll concentration between z and the surface (the chl integral divided by z).
The correct unit for kCHL is 1/(mg CHL m^{-2}).
Also note that the factor 1/z in front of the chl integral is missing in equation 5 in Fennel, Wilkin et al. (GBC 2006).
Hope this helps!
-Katja
longmtm
Location: Univ of Maryland Center for Environmental Science
Re: Light attenuation in Fasham
#3 Unread post by longmtm »
Hi Laura,
I want to confirm that Katja is right. The Unit of AttChl in the bioFasham.in file should be[m2/(mg_Chl) rather than [1/(mg_Chl m2).This should be corrected in the file ROMS/External/bioFasham.in
and also Bio(i,k,iChlo) should have unit [milligram CHL/m3]
Wen
pmaccc
#4 Unread post by pmaccc »
I think that the units of AttChl are still given incorrectly in the latest version of ROMS/External/bio_Fennel.in:
! Light attenuation by chlorophyll [1/(mg_Chl m2)], {0.02486d0}.
AttChl == 0.02486d0
Should be [m2 / (mg Chl)] right?
#5 Unread post by wilkin »
You are correct. The units of AttChl are m^2 / mg_Chl. This is because they are inverse meters per chlorophyll concentration.
At line 711 in fennel.h where AttChl is multiplied by the chlorophyll concentration (mg_Chl / m^3) it has to give units of inverse length ... to match units of AttSW ... and so that when Att (the sum of all attenuation factors) is multiplied by delta_z we have a nondimensional quantity to pass to the EXP( ) function.
                Att=(AttSW(ng)+                                         &
     &               AttChl(ng)*Bio(i,k,iChlo)+                         &
     &               AttFac)*                                           &
                ExpAtt=EXP(-Att)
