List of small bugs with ROMS/TOMS Version 2.1
#1 Unread post by arango »
Here is a list of the small bugs found in ROMS/TOMS version 2.1, released on May 5, 2005. You have the choice of correcting this small bugs yourself of getting the affected files from the roms-2 distribution directory. Please note that you need to login into the ROMS website in order to download these files. These bugs will be corrected in version 2.2; critical bugs are marked with :!: :
(1) analytical.F: few changes in this user routine.
(2) biology.F: replace CPP directive from # ifdef BIO_FASHAM to # if defined BIO_FASHAM in line 21. In some computers compilation may fail when nonstandard CPP constructs are used.
(3) def_his.F, def_rst.F: Add conditional to use mod_sediment when BBL_MODEL is activated in line 19.
Change
#ifdef SEDIMENT
to
#if defined SEDIMENT || defined BBL_MODEL
(4) def_station.F: add USE mod_sediment at line 19 to avoid compiler errors when SEDIMENT and STATIONS options are activated. Add the following statements:
      USE mod_sediment
(5) inp_par.F: Change format writing statement format to WRITE (out,110) 'idBott' in line 3886 and add the following statement in line 4083:
 110  FORMAT (/,' READ_StaPAR - variable info not yet loaded, ', a)
(6) inp_par.F: Change writing statement format to WRITE (out,80) in line 4005.
(7) mod_ncparam.F: If BIO_FASHAM is defined and CARBON undefined, the compiler stops with undefined variable messages for this module during compilation. This is because the carbon-related variables are not wrapped in an #ifdef CARBON ... #endif block. Insert a # ifdef CARBON in line 856, just before CASE ('idTvar(iTIC_)') and # endif at line 863, after the statement idTvar(iSDeC)=varid. Similarly, insert a # ifdef CARBON in line 922, just before CASE ('idTbry (iwest,iSDeC)') and # endif at line 951, after the statement idTbry(inorth,iTALK)=varid.
(8) master.F: add #include "cppdefs.h" at the top on line 1. Otherwise, the conditional for AIR_OCEAN will never executed.
(9) mod_ocean.F: remove the conditional for BBL_MODEL in line 246. That is, change line 246 to:
# ifdef SEDIMENT
(10) sg_bbl.F: remove # undef SG_LOGINT at line 2 to allow lograrithmic interpolation within the bottom boundary layer when the reference current height is less than sg_z1min.
(11) sg_bbl.F: A comma is missing at the end of the angler argument to routine bblm_tile at line 74.
(12) sg_bbl.F: Add declaration for real scalar cff3 in the local variable declaration section around line 170.
(13) step_floats.F: The shape matching rules of actual arguments and dummy arguments have been violated at line 210 when FLOAT_VWALK is defined.
Change
      CALL nrng (iseed, nudg(Lstr), Lend-Lstr+1, ierr)
to
      CALL nrng (iseed, nudg(Lstr:Lend), Lend-Lstr+1, ierr)
(14) step2d.F: correct wrong sign difference in the computation of the barotropic pressure gradient term when VAR_RHO_2D is activated in line 814 :!:
Change
#if defined VAR_RHO_2D && defined SOLVE3D
     &                     (h(i,j)-h(i,j-1))*                           &
to
     &                     (h(i,j-1)-h(i,j))*                           &
(15) wrt_his.F (line 26), wrt_rst.F (line 21), wrt_station.F (line 26): Add conditional to use mod_sediment when BBL_MODEL is activated.
Change
#ifdef SEDIMENT
to
(16) wrt_station.F: Change argument to extract2d. That is, change semicolon to colon in line 865 as follows:
     &                    scale, OCEAN(ng)%bottom(:,;,i),               &
