Release passive tracers at a certain time instead of begining
auroralin
#1 Unread post by auroralin »
Hi, all.
I would like to release tracers at a certain time after model initialization (just like to release floats at Ft0 after initialization), but I dont know how to do that. Would there be a way to realize that?
Welcome to any thoughts and ideas, thanks ;)
Re: Release passive tracers at a certain time instead of begining
#2 Unread post by wilkin »
The only way to do this is to stop the model, add the passive dye to the last history file, and restart with the modified file as initial conditions.
auroralin
#3 Unread post by auroralin »
OK, I understand. Thank you for your timely reply.
marcmestres
Location: LIM-CIIRC (Universitat Politècnica de Catalunya)
#4 Unread post by marcmestres »
I had a similar issue some time ago, releasing a passive tracer into operational simulations at t = t0 + 1 day. I solved this by modifying some code in step3d_t.F, following the suggestions given in https://www.myroms.org/forum/viewtopic. ... 969#p22969.
Best regards,
Marc
Kosa
#5 Unread post by Kosa »
Depending on what you're trying to achieve, passive tracers can also be introduced via rivers. And you can adjust their concentration to only release at a certain time.
