The issue of higher salinity.
yxli
#1 Unread post by yxli »
Hello everyone! I'm a beginner with ROMS.
After running WRF-ROMS to obtain results for February 1-7, 2014, I noticed that the salinity is higher and the flow field is inconsistent compared to the CMEMS results. How can I improve the accuracy of my simulation?The western and northern boundaries are set to Clo, and temperature and salinity are set to Gra. The MY25_MIXING scheme is used in the .h file.Image
What aspects should I focus on to improve the model?
ocean_sandy.in.txt
(163.42 KiB) Downloaded 305 times
sandy.h.txt
(2.33 KiB) Downloaded 278 times
yxli
Re: The issue of higher salinity.
#2 Unread post by yxli »
Due to issues with the image, I've uploaded a PDF version.
roms_cemes_salt_7daysmean_uv.pdf
(194.31 KiB) Downloaded 342 times
