I feel like that there is potential error in ROMS Native Sea Ice model for description of sea ice albedo and short wave flux at the water surface.
I was checking whether the ROMS Native Sea Ice model resolves light reflection and attenuation by sea ice.
And looks like that there is no sea ice light reflection term in the code, in terms of short wave radiation.
Below are the code for L1168-1188 of "Nonlinear/bulk_flux.F" (https://github.com/myroms/roms/blob/dev ... 1-L1188C65; presumed that this is the latest version of ROMS);
# if defined ALBEDO && defined SHORTWAVE
!! srflx(i,j) = srflx(i,j)*(1.0_r8-albedo(i,j))
# if defined ICE_MODEL && defined ICE_BULK_FLUXES
! Limit shortwave radiation to be used in computing penetrative
! radiation by presence of ice alone.
cff1=1.0_r8/(Si(i,j,li_stp,isAice)+eps)
ice_thick(i,j) =Si(i,j,li_stp,isHice)*cff1
snow_thick(i,j)=Si(i,j,li_stp,isHsno)*cff1
IF (ice_thick(i,j).le.0.1_r8) THEN
cff2=ice_thick(i,j)*5.0_r8
ELSE
cff2=0.1_r8*(5.0_r8+(ice_thick(i,j)-0.1_r8))
ENDIF
cff2=cff2+snow_thick(i,j)*20.0_r8
srflx(i,j)=(1.0_r8-Si(i,j,li_stp,isAice))*srflx(i,j)+ &
& Si(i,j,li_stp,isAice)*srflx(i,j)*EXP(-cff2)
I can see the light attenuation terms at the end of the lines (L1187-1188) but light reflectance term looks like be commented (L1169).
I checked a possibility for that the light reflectance term exists in the other file, but I cannot find it to the best of my knowledge...
In my understanding, the first three lines need to be
# if defined ICE_ALBEDO
srflx(i,j) = srflx(i,j)*(1.0_r8-albedo_ice(i,j))
I might be wrong, so correction for my understanding, or any comments, will be really appreciated.
Best regards,
Jang
