error while reading variable: Uwind at TIME index = 1
sougata24
#1 Unread post by sougata24 »
I am new to ROMS and currently trying give my first roms run. While running the model I encounter the below mentioned error where something is wrong with reading the variable Uwind.
I am using the era5 forcing with hourly interval.
PART OF THE LOG:
 GET_STATE_NF90   - NLM: state initial conditions,                       2020-01-01 00:00:00.00
                      (Grid 01, t = 737424.0000, File: roms_ic_Arabian_sea.nc, Rec=0001, Index=1)
                   - free-surface
                      (Min = -4.00000028E-02 Max =  5.30000031E-01)
                      (Min = -5.55421315E+00 Max =  4.75273181E-01)
                      (Min = -7.89665369E-01 Max =  4.71052604E+00)
                   - u-momentum component
                      (Min = -1.29196531E+00 Max =  8.57396294E-01)
                   - v-momentum component
                      (Min = -9.19391158E-01 Max =  1.03296812E+00)
                   - potential temperature
                      (Min =  1.16246295E+00 Max =  2.78663485E+01)
                   - salinity
                      (Min =  3.47229996E+01 Max =  3.62876484E+01)
PROBLEM STATEMENT IN THE LOG :
REGRID - input gridded data does not contain model grid:
          Gridded:  LonMin =   50.0000 LonMax =   58.0000
                    LatMin =    8.0000 LatMax =   14.0000
          Model:    LonMin =   50.0715 LonMax =   58.3698
                    LatMin =    8.5862 LatMax =   14.8747
 Found Error: 04   Line: 355      Source: ROMS/Utility/get_2dfld.F, get_2dfld_nf90
 GET_2DFLD_NF90 - error while reading variable: Uwind   at TIME index = 1
 Found Error: 04   Line: 112      Source: ROMS/Utility/get_2dfld.F
 Found Error: 04   Line: 169      Source: ROMS/Nonlinear/get_data.F
 Found Error: 04   Line: 671      Source: ROMS/Nonlinear/initial.F
 Found Error: 04   Line: 197      Source: ROMS/Drivers/nl_roms.h, ROMS_initialize
Any help will be greatly appreciated!
AS_upwelling.log
(32 KiB) Downloaded 146 times
Re: error while reading variable: Uwind at TIME index = 1
the model goes to 58.3698, but the data only extends to 58.00
you need to have the data span the entire model grid.
same idea for lat.
