Not able to use the make_remap_weights_file.py file
sougata24
#1 Unread post by sougata24 »
I am trying to build the Initial conditions and forcing for ROMS using the pyroms module. But while trying to run the make_remap_weights_file.py script I am constantly getting this error:
Assuming spherical is integer b'T' <class 'numpy.ma.core.MaskedArray'>
Load geographical grid from file
grid shape 40 20
grid shape 40 19
grid shape 39 20
At line 138 of file ./pyscrip.f90 (unit = 1)
Fortran runtime error: Bad FORM parameter in OPEN statement
From previous issues posted here, I got to know that it's better to use xesmf for remapping. But when I am trying to run make_remap_weights_file_ARCTIC_HYCOM_GLBy.py script, the process is getting killed.
I am new to ROMS, so any kind of help would be highly appreciated.
Re: Not able to use the make_remap_weights_file.py file
With xesmf, you don’t run make_remap_weights_file.py. I should delete that.
sougata24
#3 Unread post by sougata24 »
Thanks!
I tried to run the make_bdry_file.py first but after some time the process gets killed.
Does it have something to do with the domain size ?
I have attached the log file here as well (bdry.log).
bdry.log
(669.1 MiB) Downloaded 2181 times
I don't know what to make of the log file. Yes, your domain size could cause it to run out of memory and get killed.
sougata24
#5 Unread post by sougata24 »
I reduced the domain size and tried to run the make_bdry_file.py
I am getting something like :
ValueError: could not broadcast input array from shape (100,) into shape (1,)
Could you please tell me what could be causing this error ?
#6 Unread post by kate »
It's clear enough, right? You need to look at what line number, what variables it is talking about. I often
add print statements to find out the shapes of things. You might also learn to use breakpoint() to get
into the debugger to query your variables.
