Virtual dye sources problem
baewell
#1 Unread post by baewell »
I would like to add a continuous virtual dye source in my case like river files with NO horizontal momentum transport. Therefore, I utilized a river file to introduce a dye source at a specified location in my setup, while kept river mass transport = 0, and other settings are as follows:
      LuvSrc == T                          ! horizontal momentum transport
       LwSrc == F                          ! volume vertical influx
! [1:NAT+NPT,Ngrids].  See glossary below for details.
  LtracerSrc == F F T                       ! temperature, salinity, inert
but in the final output, the dye concentration remains consistently at 0. It seems that my approach to adding the dye source has not been successful.
I suspect the issue may be with these lines of code in step3d_uv.F. When I commented out these lines, the model blow up.
      IF (LuvSrc(ng)) THEN
        DO is=1,Nsrc(ng)
          i=SOURCES(ng)%Isrc(is)
          j=SOURCES(ng)%Jsrc(is)
          IF (((IstrR.le.i).and.(i.le.IendR)).and.                      &
     &        ((JstrR.le.j).and.(j.le.JendR))) THEN
            IF (INT(SOURCES(ng)%Dsrc(is)).eq.0) THEN
              DO k=1,N(ng)
                cff1=1.0_r8/(on_u(i,j)*                                 &
     &                       0.5_r8*(z_w(i-1,j,k)-z_w(i-1,j,k-1)+       &
     &                               z_w(i  ,j,k)-z_w(i  ,j,k-1)))
                u(i,j,k,nnew)=SOURCES(ng)%Qsrc(is,k)*cff1
            ELSE
              DO k=1,N(ng)
                cff1=1.0_r8/(om_v(i,j)*                                 &
     &                       0.5_r8*(z_w(i,j-1,k)-z_w(i,j-1,k-1)+       &
     &                               z_w(i,j  ,k)-z_w(i,j  ,k-1)))
                v(i,j,k,nnew)=SOURCES(ng)%Qsrc(is,k)*cff1
So, please help me with your insights. Any suggestions would be greatly appreciated!
Re: Virtual dye sources problem
#2 Unread post by wilkin »
You want the LwSrc option. This introduces tracer mass without momentum by augmenting the tracer flux divergence at the cell center. It does not impact u,v.
For both LuvSrc and LwSrc sources the rate at which tracer is added (in kg/s) is the volume flux (river_transport, m^3/s) multiplied by the concentration (kg/m^3). If you set "mass flux", by which I assume you mean river_transport, to zero you correctly get no net tracer flux (kg/s)
baewell
#3 Unread post by baewell »
wilkin wrote: Thu Jan 18, 2024 12:43 am You want the LwSrc option. This introduces tracer mass without momentum by augmenting the tracer flux divergence at the cell center. It does not impact u,v.
Hi, Wilkin,
many thanks for your quick and helpful reply! I will try your suggestions!
