Spatially varied bottom roughness
ShimaKasaei
#1 Unread post by ShimaKasaei »
I have a question regarding defining spatially varied Zo. I have calculated Zo for my whole domain based on C-CAP values, and I have added them as variable ZoBot to my grid file in the model.
I also defined UV_DRAG_GRID in my .h file to enable the model to use spatially varied bottom roughness.
The issue is, when I am running the model, I cannot see much changes in the velocity, although I do have max(ZoBot) of my domain equal to 0.36 meter!!
I thought maybe that is because of cdb max cap limit in the ROMS/Modules/mod_scalars.F, but it did not change after increasing the cap limit as well.
I think maybe there is an issue that model is not considering the spatially varied ZoBot, although it reads and shows in the roms_his.nc file.
Is there any step that I am missing??
Does anyone have any thoughts or suggestions?
I do appreciate any hint.
Best,
Shima
Re: Spatially varied bottom roughness
#2 Unread post by wilkin »
Do you have ...
  #define UV_LOGDRAG
ShimaKasaei
#3 Unread post by ShimaKasaei »
Yes, I have it in the .h file.
