INQUIRY_NF90 - unable to find requested variable: swflux
felipe.jbarragan7
#1 Unread post by felipe.jbarragan7 »
Hi, good morning.
I have one problem with my case, could please somebody help me ? :oops:
This is my .h
** Application flag: SANTANDER_CASE
** Input script: roms_santander_case.in
#define MIX_GEO_UV
#define ATM_PRESS
#define SPLINES_VVISC
#define SPLINES_VDIFF
#define STATIONS
#define ANA_INITIAL
#define ANA_STFLUX
#define GLS_MIXING
And the error is about unable to find requested variable: swflux
Specifically:
in files:
./Inputs/p_001_frc.nc
./Inputs/u_001_frc.nc
./Inputs/v_001_frc.nc
Found Error: 02 Line: 423 Source: ROMS/Utility/inquiry.F, inquiry_nf90
Found Error: 02 Line: 220 Source: ROMS/Utility/get_2dfld.F, get_2dfld_nf90
Found Error: 02 Line: 112 Source: ROMS/Utility/get_2dfld.F
Found Error: 02 Line: 607 Source: ROMS/Nonlinear/get_data.F
Found Error: 02 Line: 670 Source: ROMS/Nonlinear/initial.F
Found Error: 02 Line: 197 Source: ROMS/Drivers/nl_roms.h, ROMS_initialize
The 3 .nc are dates of wind and surface pressure of 3 days.
Thanks for some help.
Re: INQUIRY_NF90 - unable to find requested variable: swflux
#2 Unread post by wilkin »
It looks like you want to prescribe temperature and salinity surface boundary conditions with analytical functionals (because you have #define ANA_STFLUX). In that case you also need #define ANA_SSFLUX, otherwise the default action is to look for the data amongst the forcing netcdf file list.
felipe.jbarragan7
#3 Unread post by felipe.jbarragan7 »
Thanks so much Wilkin.
The problem was it.
But, now is other problem with:
Program received signal SIGFPE: Floating-point exception - erroneous arithmetic operation.
Backtrace for this error:
#0 0x7fc355a6e960 in ???
#1 0x7fc355a6dac5 in ???
#2 0x7fc35575e51f in ???
#3 0x561b93338719 in __mod_netcdf_MOD_netcdf_get_fvar_1d
at /home/felipejbarragan11/roms_project/test/MyTest/ROMSSantander/Build_romsG/mod_netcdf.f90:1845
#4 0x561b936fdf93 in get_ngfld_nf90_
at /home/felipejbarragan11/roms_project/test/MyTest/ROMSSantander/Build_romsG/get_ngfld.f90:285
#5 0x561b936fffb7 in get_ngfld_
at /home/felipejbarragan11/roms_project/test/MyTest/ROMSSantander/Build_romsG/get_ngfld.f90:82
#6 0x561b934fa0db in get_data_
at /home/felipejbarragan11/roms_project/test/MyTest/ROMSSantander/Build_romsG/get_data.f90:149
#7 0x561b92c1554d in initial_
at /home/felipejbarragan11/roms_project/test/MyTest/ROMSSantander/Build_romsG/initial.f90:250
#8 0x561b92c12e75 in __roms_kernel_mod_MOD_roms_initialize
at /home/felipejbarragan11/roms_project/test/MyTest/ROMSSantander/Build_romsG/roms_kernel.f90:134
#9 0x561b92c118f3 in myroms
at /home/felipejbarragan11/roms_project/test/MyTest/ROMSSantander/Build_romsG/master.f90:75
#10 0x561b92c11b5a in main
at /home/felipejbarragan11/roms_project/test/MyTest/ROMSSantander/Build_romsG/master.f90:50
Floating point exception
Is finally, after run it
Model Input Parameters: ROMS/TOMS version 4.2
Wednesday - August 23, 2023 - 10:36:09 AM
Santander Test
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler flags : -frepack-arrays -fallow-argument-mismatch -g -O0 -fbounds-check -fbacktrace -fcheck=all -finit-real=nan -ffpe-trap=invalid,zero,overflow -
SVN Revision : 1177
Local Root : /home/felipejbarragan11/roms/trunk
Header Dir : /home/felipejbarragan11/roms_project/test/MyTest/ROMSSantander
Header file : santander_case.h
Analytical Dir : /home/felipejbarragan11/roms_project/test/MyTest/ROMSSantander
Resolution, Grid 01: 1366x220x15, Parallel Threads: 1, Tiling: 1x1
288 ntimes Number of timesteps for 3-D equations.
60 ndtfast Number of timesteps for 2-D equations between
72 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
1 nSTA Number of timesteps between the writing of data
the stations file.
into history file.
into quicksave file.
1.5000E+01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
2.0000E-02 Akv_bak Background vertical mixing coefficient (m2/s)
for turbulent energy.
1.5000E-03 rdrg2 Quadratic bottom drag coefficient.
8.0000E+00 theta_s S-coordinate surface control parameter.
4.0000E+00 theta_b S-coordinate bottom control parameter.
20.000 Tcline S-coordinate surface/bottom layer width (m) used
730319.000 dstart Time-stamp assigned to model initialization (days).
19000101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
for 3D momentum.
of State.
1 inp_lib Using standard NetCDF library for input files.
1 out_lib Using standard NetCDF library for output files.
Output Restart File: ./Outputs/p2_frc_y_bry_rst.nc
Output History File: ./Outputs/p2_frc_y_bry_his.nc
Output Stations File: p2_frc_y_bry_sta.nc
Input Grid File: ./Inputs/seagrid_Malla_Detalle_mejorada_325m_smooth10.nc
Input Forcing File 01: ./Inputs/p_001_frc.nc
Input Forcing File 02: ./Inputs/u_001_frc.nc
Input Forcing File 03: ./Inputs/v_001_frc.nc
Input Lateral Boundary File 01: ./Inputs/001_bry.nc
Station positions File: ./Inputs/stations_Bimep_MallaDetalle_325m.in
ROMS I/O variables Metadata File: /home/felipejbarragan11/roms_project/test/varinfo.yaml
Tile partition information for Grid 01: 1366x220x15 tiling: 1x1
tile Istr Iend Jstr Jend Npts
0 1 1366 1 220 4507800
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 -2.50 1369.50 -2.50 223.50 RHO-points
0 -3.00 1369.00 -2.50 223.50 U-points
0 -2.50 1369.50 -3.00 223.00 V-points
Stations Parameters, Grid: 01
12 Nstation Number of stations to write out into stations file.
T Sout(idFsur) Write out free-surface.
T Sout(idUbar) Write out 2D U-momentum component.
T Sout(idVbar) Write out 2D V-momentum component.
T Sout(idUvel) Write out 3D U-momentum component.
T Sout(idVvel) Write out 3D V-momentum component.
T Sout(idWvel) Write out W-momentum component.
T Sout(idDano) Write out density anomaly.
T Sout(idVvis) Write out vertical viscosity coefficient.
T Sout(idTdif) Write out vertical T-diffusion coefficient.
T Sout(idSdif) Write out vertical S-diffusion coefficient.
Flag and positions for station 0001: 0 822.0000 68.0000
Flag and positions for station 0002: 0 827.0000 68.0000
Flag and positions for station 0003: 0 830.0000 71.0000
Flag and positions for station 0004: 0 833.0000 74.0000
Flag and positions for station 0005: 0 833.0000 77.0000
Flag and positions for station 0006: 0 827.0000 77.0000
Flag and positions for station 0007: 0 822.0000 72.0000
Flag and positions for station 0008: 0 769.0000 132.0000
Flag and positions for station 0009: 0 826.0000 74.0000
Flag and positions for station 0010: 0 211.0000 29.0000
Flag and positions for station 0011: 0 484.0000 80.0000
Flag and positions for station 0012: 0 630.0000 80.0000
Tracer Advection Scheme: NLM
Variable Grid Horizontal Vertical
temp 1 MPDATA MPDATA
salt 1 MPDATA MPDATA
Akima4 Fourth-order Akima advection
Centered2 Second-order centered differences advection
Centered4 Fourth-order centered differences advection
HSIMT Third High-order Spatial Inteporlation at Middle Time Advection with TVD limiter
MPDATA Multidimensional Positive Definite Advection Algorithm, recursive method
Splines Conservative Parabolic Splines Reconstruction Advection (only vertical; not recommended)
Split_U3 Split third-order Upstream Advection
Upstream3 Third-order Upstream-biased Advection (only horizontal)
zeta 1 Chapman Imp Closed Closed Chapman Imp
ubar 1 Flather Closed Closed Flather
vbar 1 Flather Closed Closed Flather
u 1 Periodic Periodic Periodic Periodic
v 1 Periodic Periodic Periodic Periodic
temp 1 Periodic Periodic Periodic Periodic
salt 1 Periodic Periodic Periodic Periodic
tke 1 Periodic Periodic Periodic Periodic
SANTANDER_CASE Santander Test
ANA_INITIAL Analytical initial conditions
ANA_SSFLUX Analytical kinematic surface salinity flux
ANA_STFLUX Analytical kinematic surface temperature flux
ATM_PRESS Impose inverse barometer effect in pressure gradient term
CURVGRID Orthogonal curvilinear grid
DJ_GRADPS Parabolic Splines density Jacobian (Shchepetkin, 2002)
DOUBLE_PRECISION Double precision arithmetic numerical kernel.
GLS_MIXING Generic Length-Scale turbulence closure
MASKING Land/Sea masking
MIX_GEO_UV Mixing of momentum along geopotential surfaces
NONLINEAR Nonlinear Model
!NONLIN_EOS Linear Equation of State for seawater
K_GSCHEME Third-order upstream advection of TKE fields
SALINITY Using salinity
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity
STATIONS Writing out station data
UV_ADV Advection of momentum
UV_COR Coriolis term
UV_QDRAG Quadratic bottom stress
Process Information:
Thread # 0 (pid= 21676) is active.
GET_GRID_NF90 - angle between XI-axis and EAST: angler
(Grid = 01, File: ./Inputs/seagrid_Malla_Detalle_mejorada_325m_smooth10.nc)
(Min = -2.14939282E-10 Max = 7.04179173E-11)
GET_GRID_NF90 - reciprocal XI-grid spacing: pm
(Min = 4.22257608E-03 Max = 4.26819532E-03)
GET_GRID_NF90 - reciprocal ETA-grid spacing: pn
(Min = 3.05496680E-03 Max = 3.08797128E-03)
GET_GRID_NF90 - XI-derivative of inverse metric factor pn: dndx
(Min = -1.73926871E-05 Max = 2.07980104E-05)
GET_GRID_NF90 - ETA-derivative of inverse metric factor pm: dmde
(Min = -1.14902121E-02 Max = 0.00000000E+00)
GET_GRID_NF90 - Coriolis parameter at RHO-points: f
(Min = 9.99313979E-05 Max = 1.01124653E-04)
GET_GRID_NF90 - bathymetry at RHO-points: h
(Min = 5.00000000E+00 Max = 3.24060637E+03)
GET_GRID_NF90 - x-location of RHO-points: x-rho
(Min = -5.89199676E+05 Max = -1.44723125E+05)
GET_GRID_NF90 - y-location of RHO-points: y_rho
(Min = 5.34460443E+06 Max = 5.44392601E+06)
GET_GRID_NF90 - x-location of PSI-points: x_psi
(Min = -5.89037102E+05 Max = -1.44885699E+05)
GET_GRID_NF90 - y-location of PSI-points: y-psi
(Min = 5.34482914E+06 Max = 5.44370130E+06)
GET_GRID_NF90 - x-location of U-points: x_u
GET_GRID_NF90 - y-location of U-points: y_u
GET_GRID_NF90 - x-location of V-points: x_v
GET_GRID_NF90 - y-location of V-points: y_v
GET_GRID_NF90 - longitude of RHO-points: lon_rho
(Min = -5.29853801E+00 Max = -1.30146199E+00)
GET_GRID_NF90 - latitude of RHO-points lat_rho
(Min = 4.32514718E+01 Max = 4.38985439E+01)
GET_GRID_NF90 - longitude of PSI-points: lon_psi
(Min = -5.29707602E+00 Max = -1.30292398E+00)
GET_GRID_NF90 - latitude of PSI-points lat_psi
(Min = 4.32529437E+01 Max = 4.38970878E+01)
GET_GRID_NF90 - longitude of U-points: lon_u
GET_GRID_NF90 - latitude of U-points: lat_u
GET_GRID_NF90 - longitude of V-points: lon_v
GET_GRID_NF90 - latitude of V-points: lat_v
GET_GRID_NF90 - mask on RHO-points: mask_rho
(Min = 0.00000000E+00 Max = 1.00000000E+00)
GET_GRID_NF90 - mask on PSI-points: mask_psi
GET_GRID_NF90 - mask on U-points: mask_u
GET_GRID_NF90 - mask on V-points: mask_v
15 0.0000000 0.0000000 0.000 0.000 0.000 0.000
14 -0.0666667 -0.0003983 -0.267 -0.671 -1.956 -2.608
13 -0.1333333 -0.0017081 -0.535 -1.350 -5.372 -8.152
12 -0.2000000 -0.0043062 -0.804 -2.043 -10.854 -17.845
11 -0.2666667 -0.0089353 -1.076 -2.756 -19.592 -34.079
10 -0.3333333 -0.0169029 -1.350 -3.502 -33.682 -61.066
9 -0.4000000 -0.0304126 -1.630 -4.304 -56.655 -105.902
8 -0.4666667 -0.0530642 -1.920 -5.197 -94.284 -180.182
7 -0.5333333 -0.0905094 -2.224 -6.238 -155.628 -302.107
6 -0.6000000 -0.1510347 -2.551 -7.510 -253.970 -498.368
5 -0.6666667 -0.2452550 -2.912 -9.119 -406.326 -803.152
4 -0.7333333 -0.3828872 -3.316 -11.162 -628.274 -1247.753
3 -0.8000000 -0.5634305 -3.763 -13.634 -919.011 -1830.559
2 -0.8666667 -0.7610631 -4.228 -16.277 -1237.142 -2468.405
1 -0.9333333 -0.9210683 -4.654 -18.544 -1494.955 -2985.064
0 -1.0000000 -1.0000000 -5.000 -20.000 -1622.803 -3240.606
Time Splitting Weights for Grid 01: ndtfast = 60 nfast = 83
1-0.0003540175431531 0.0166666666666667-0.0003540175431531 0.0166666666666667
2-0.0006728864853186 0.0166725669590526-0.0010269040284716 0.0333392336257192
3-0.0009566069754562 0.0166837817338079-0.0019835110039279 0.0500230153595271
4-0.0012051795928536 0.0166997251833988-0.0031886905967814 0.0667227405429259
5-0.0014186058436584 0.0167198115099464-0.0046072964404399 0.0834425520528722
6-0.0015968888560238 0.0167434549406740-0.0062041852964637 0.1001860069935462
7-0.0017400342738662 0.0167700697549411-0.0079442195703299 0.1169560767484873
8-0.0018480513492362 0.0167990703261722-0.0097922709195661 0.1337551470746595
9-0.0019209542333024 0.0168298711819928-0.0117132251528686 0.1505850182566522
10-0.0019587634659484 0.0168618870858811-0.0136719886188169 0.1674469053425334
11-0.0019615076639817 0.0168945331436469-0.0156334962827987 0.1843414384861803
12-0.0019292254079571 0.0169272249380466-0.0175627216907558 0.2012686634242269
13-0.0018619673276114 0.0169593786948459-0.0194246890183672 0.2182280421190729
14-0.0017597983859117 0.0169904114836395-0.0211844874042789 0.2352184536027123
15-0.0016228003617172 0.0170197414567380-0.0228072877659961 0.2522381950594503
16-0.0014510745310524 0.0170467881294333-0.0242583622970485 0.2692849831888836
17-0.0012447445469948 0.0170709727049508-0.0255031068440433 0.2863559558938343
18-0.0010039595181742 0.0170917184474007-0.0265070663622175 0.3034476743412350
19-0.0007288972858858 0.0171084511060370-0.0272359636481033 0.3205561254472720
20-0.0004197678998158 0.0171205993941351-0.0276557315479191 0.3376767248414071
21-0.0000768172923796 0.0171275955257987-0.0277325488402987 0.3548043203672058
22 0.0002996688483262 0.0171288758140050-0.0274328799919725 0.3719331961812107
23 0.0007093610069602 0.0171238813331995-0.0267235189850123 0.3890570775144103
24 0.0011518815707581 0.0171120586497502-0.0255716374142542 0.4061691361641604
25 0.0016268003607435 0.0170928606235709-0.0239448370535106 0.4232619967877314
26 0.0021336299643244 0.0170657472842252-0.0218112070891863 0.4403277440719565
27 0.0026718208692771 0.0170301867848198-0.0191393862199091 0.4573579308567763
28 0.0032407563991181 0.0169856564369985-0.0158986298207911 0.4743435872937748
29 0.0038397474498617 0.0169316438303465-0.0120588823709294 0.4912752311241213
30 0.0044680270281659 0.0168676480395155-0.0075908553427635 0.5081428791636368
31 0.0051247445908649 0.0167931809223794-0.0024661107518986 0.5249360600860161
32 0.0058089601858883 0.0167077685125316 0.0033428494339897 0.5416438285985478
33 0.0065196383945684 0.0166109525094335 0.0098624878285581 0.5582547811079812
34 0.0072556420753336 0.0165022918695240 0.0171181299038917 0.5747570729775052
35 0.0080157259087899 0.0163813645016018 0.0251338558126816 0.5911384374791070
36 0.0087985297441882 0.0162477690697886 0.0339323855568698 0.6073862065488956
37 0.0096025717472802 0.0161011269073855 0.0435349573041500 0.6234873334562812
38 0.0104262413495604 0.0159410840449308 0.0539611986537104 0.6394284175012119
39 0.0112677919988951 0.0157673133557715 0.0652289906526054 0.6551957308569835
40 0.0121253337115396 0.0155795168224566 0.0773543243641450 0.6707752476794401
41 0.0129968254255413 0.0153774279272642 0.0903511497896863 0.6861526756067043
42 0.0138800671555305 0.0151608141701719 0.1042312169452169 0.7013134897768762
43 0.0147726919488984 0.0149294797175797 0.1190039088941153 0.7162429694944560
44 0.0156721576433617 0.0146832681850981 0.1346760665374769 0.7309262376795540
45 0.0165757384259147 0.0144220655577087 0.1512518049633916 0.7453483032372628
46 0.0174805161931688 0.0141458032506101 0.1687323211565604 0.7594941064878729
47 0.0183833717130782 0.0138544613140573 0.1871156928696386 0.7733485678019302
48 0.0192809755880535 0.0135480717855060 0.2063966684576921 0.7868966395874362
49 0.0201697790194623 0.0132267221923718 0.2265664474771545 0.8001233617798079
50 0.0210460043735164 0.0128905592087141 0.2476124518506709 0.8130139209885220
51 0.0219056355485466 0.0125397924691555 0.2695180873992175 0.8255537134576775
52 0.0227444081436646 0.0121746985433464 0.2922624955428820 0.8377284120010239
53 0.0235577994288118 0.0117956250742853 0.3158202949716938 0.8495240370753092
54 0.0243410181161952 0.0114029950838051 0.3401613130878890 0.8609270321591143
55 0.0250889939331104 0.0109973114485352 0.3652503070209994 0.8719243436076495
56 0.0257963669961522 0.0105791615496500 0.3910466740171517 0.8825035051572995
57 0.0264574769868114 0.0101492220997141 0.4175041510039630 0.8926527272570136
58 0.0270663521284594 0.0097082641499339 0.4445705031324225 0.9023609914069476
59 0.0276166979647200 0.0092571582811263 0.4721872010971425 0.9116181496880739
60 0.0281018859392274 0.0087968799817143 0.5002890870363698 0.9204150296697882
61 0.0285149417767724 0.0083285152160605 0.5288040288131421 0.9287435448858486
62 0.0288485336658351 0.0078532661864476 0.5576525624789772 0.9365968110722963
63 0.0290949602425050 0.0073724572920170 0.5867475227214822 0.9439692683643134
64 0.0292461383757876 0.0068875412879753 0.6159936610972698 0.9508568096522887
65 0.0292935907542990 0.0064001056483788 0.6452872518515688 0.9572569153006675
66 0.0292284332743468 0.0059118791358072 0.6745156851259155 0.9631687944364746
67 0.0290413622293988 0.0054247385812347 0.7035570473553143 0.9685935330177093
68 0.0287226413009382 0.0049407158774114 0.7322796886562525 0.9735342488951207
69 0.0282620883507063 0.0044620051890625 0.7605417770069588 0.9779962540841832
70 0.0276490620143322 0.0039909703832173 0.7881908390212909 0.9819872244674006
71 0.0268724480963495 0.0035301526829785 0.8150632871176404 0.9855173771503791
72 0.0259206457666001 0.0030822785480393 0.8409839328842404 0.9885996556984185
73 0.0247815535580255 0.0026502677852627 0.8657654864422659 0.9912499234836811
74 0.0234425551658447 0.0022372418926289 0.8892080416081106 0.9934871653763100
75 0.0218905050481194 0.0018465326398648 0.9110985466562300 0.9953336980161748
76 0.0201117138277064 0.0014816908890628 0.9312102604839364 0.9968153889052376
77 0.0180919334955968 0.0011464956586011 0.9493021939795332 0.9979618845638386
78 0.0158163424156430 0.0008449634336744 0.9651185363951762 0.9988068479975131
79 0.0132695301306719 0.0005813577267471 0.9783880665258481 0.9993882057242601
80 0.0104354819699857 0.0003601988912359 0.9888235484958338 0.9997484046154960
81 0.0072975634582500 0.0001862741917361 0.9961211119540838 0.9999346788072321
82 0.0038385045257686 0.0000646481340986 0.9999596164798524 0.9999993269413306
83 0.0000403835201471 0.0000006730586691 0.9999999999999994 0.9999999999999998
ndtfast, nfast = 60 83 nfast/ndtfast = 1.38333
1.000000000000 1.029032332991 0.514516166496 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.23667
Minimum X-grid spacing, DXmin = 2.34302513E-01 km Water points = 2.34302513E-01 km
Maximum X-grid spacing, DXmax = 2.36810811E-01 km Water points = 2.36673422E-01 km
Minimum Y-grid spacing, DYmin = 3.23853046E-01 km Water points = 3.23853046E-01 km
Maximum Y-grid spacing, DYmax = 3.27319980E-01 km Water points = 3.27130115E-01 km
Minimum Z-grid spacing, DZmin = 2.67064963E-01 m Water points = 2.67064963E-01 m
Maximum Z-grid spacing, DZmax = 6.37846123E+02 m Water points = 6.37846123E+02 m
Minimum barotropic Courant Number = 1.82621184E-01
Maximum barotropic Courant Number = 4.68960547E+00
Maximum Coriolis Courant Number = 3.03357933E-02
(Grid = 01, Min = 1.40000000E+01 Max = 1.40000000E+01)
ANA_INITIAL - salinity: salt
(Grid = 01, Min = 3.50000000E+01 Max = 3.50000000E+01)
GET_2DFLD_NF90 - surface u-momentum stress, 3899-07-19 00:00:00.00
(Grid=01, Rec=1, Index=1, File: u_001_frc.nc)
(Tmin= 730319.0000 Tmax= 730321.9583) t = 730319.0000
(Min = -1.29668912E-05 Max = 1.41368562E-04) regrid = T
GET_2DFLD_NF90 - surface v-momentum stress, 3899-07-19 00:00:00.00
(Grid=01, Rec=1, Index=1, File: v_001_frc.nc)
(Min = -6.97489772E-05 Max = 4.17267946E-05) regrid = T
GET_2DFLD_NF90 - surface air pressure, 3899-07-19 00:00:00.00
(Grid=01, Rec=1, Index=1, File: p_001_frc.nc)
(Min = 1.01346806E+03 Max = 1.01818100E+03) regrid = T
Please could you help me?
#4 Unread post by wilkin »
Read the Backtrace for this error.
This shows the ultimate failure is associated with trying to read from a netcdf file. But which file? The particular netcdf read was initiated at
So, in your build directory, open file get_data.f90 and see what data it was trying to read at line 149. That should give you a clue.
Alternatively, at the very end of you log you also have the information
That tells you where to look (line 607) in get_data.F for what ROMS was doing when the error occurred.
The log shows ROMS read the first record from each netcdf forcing file. I think the next thing to happen should be to read the second record from each file that it will use to interpolate in time to the model time as the run proceeds. You might want to check whether those files are OK.
felipe.jbarragan7
#5 Unread post by felipe.jbarragan7 »
Thank so much for your help Wilkin
I'll do it and check the files
Thanks.
