Why temperature at t=2 and so on looks strange?
Cool Findings and Plots
remit
#1 Unread post by remit »
I have a problem with the output history in the display of sea temperature. In the initial time step (t=1, first image), the result is fine with no anomalies. However, when I open the results at the second time step (t=2, second image), and onwards, there is an unusual value at the southern boundary. The ROMS model runs successfully until the final timestep. I have attached the bathymetry used (third image) header and log files for reference.
For your information, I am using the following settings:
Theta_s=1
Theta_b=1
Vtransform=2
Vstretching=4
I have tried different values for theta_s and theta_b, but the results remain the same.
The lateral boundary conditions (LBC) are set as follows:
   LBC(isFsur) ==   Cha     Cha     Cha     Cha         ! free-surface
   LBC(isUbar) ==   Shc     Shc     Shc     Shc         ! 2D U-momentum
   LBC(isVbar) ==   Shc     Shc     Shc     Shc         ! 2D V-momentum
   LBC(isUvel) ==   RadNud  RadNud  RadNud  RadNud         ! 3D U-momentum
   LBC(isVvel) ==   RadNud  RadNud  RadNud  RadNud         ! 3D V-momentum
   LBC(isMtke) ==   RadNud  RadNud  RadNud  RadNud         ! mixing TKE
   LBC(isTvar) ==   RadNud  RadNud  RadNud  RadNud \       ! temperature
                    RadNud  RadNud  RadNud  RadNud         ! salinity
I hope this information helps in diagnosing the issue. Please let me know if anyone has any suggestions or needs further clarification.
tks.
roms_only.h
(1.96 KiB) Downloaded 973 times
roms_log.log
(4.61 MiB) Downloaded 1053 times
Re: Why temperature at t=2 and so on looks strange?
I would guess that it's more of a vertical mixing problem than an open boundary problem. Have you looked at vertical cross sections?
